Results 1 to 7 of 7
Like Tree3Likes
  • 2 Post By s14tat
  • 1 Post By funkylogik
    Default S3 or s3 lte How can we tell the difference.
    Hi, I've just bought a S3 online. Its says you may get the LTE version depending on Country. How can you tell if its an LTE phone?
    Many thanks
  2. #2
    s14tat's Avatar
    Posts
    ROM
    AOKP ICS build 38
    Default Re: S3 or s3 lte How can we tell the difference.
    look at the model number, its its not a i9300, it is probably lte.
    Thanked by:
    Dr_AJ
    funkylogik and Dr_AJ like this.
    Thank you,
    I'm a day one newbie convert from the other side, so what might be obvious to some is a bit daunting.
    I appreciate the help.
  4. #4
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Quote Originally Posted by s14tat View Post
    or gt-i9300T i "think"
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    GT-I9300, UK
    Thanked by:
    Dr_AJ
    Dr_AJ likes this.
  5. #5
    s14tat's Avatar
    Posts
    ROM
    AOKP ICS build 38
    I forgot to add that the T mobile version is not LTE either, so if its not a i9300 or T999 you should be good go. If you already have the phone on hand, go to settings and go to about device. It would give you a model number there.
  6. #6
    Would it also not have the "LTE" logo on the top next to the 4G?
  7. #7
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    he hasnt got it set up yet. it was shipped in french language so any help in thn "language change" thread would be appreciated guys
    its a gt-i9300 btw
    GT-I9300, UK
  1. How can I tell if a battery is REAL or not?
    By The Hustleman in forum Samsung Galaxy S3
    Last Post: 08-27-2012, 02:55 PM
  2. How can I tell if Asurion insurance replacement GN is new or used
    By af250xxl in forum Verizon Galaxy Nexus
    Last Post: 01-17-2012, 05:42 PM
  3. How can I tell if my HTC Evo 4G is new or a refurb?
    By captwendy in forum Introductions
    Last Post: 11-30-2011, 08:58 AM
  4. How can you tell if your cpu is permanently damaged?
    By Brett in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 05-05-2010, 04:05 PM
  5. How can you tell if your Nexus one is rooted
    By Devyne1 in forum Google / HTC Nexus One
    Last Post: 04-11-2010, 08:23 AM
