- 10-01-2012, 04:20 PM
Thread Author #1
How to close Gsam battery monitor?
I downloaded Gsam to monitor which apps are using my battery but when I hit the home button, there is the Gsam battery icon on the top left of the notification bar. There isn't an option in the menu to Exit out of the app nor will it close or go away when I kill it with by holding down home to bring up the recent apps list and swiping left to kill it. How do I get rid of it so that it's not running in the background and sucking up battery?
- 10-01-2012, 05:21 PM #2
Re: How to close Gsam battery monitor?
it doesnt use much battery and without it running in background, its useless as it cant "learn" your average battery use so may as well uninstall it but you can go to settings, app manager, gsam, force stop
..on my phone it uses 0.1% battery lol
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
GT-I9300, UK
- 10-01-2012, 05:26 PM #3
p.s, in Gsam preferences you theres option to remove the statusbar icon if it annoys you
GT-I9300, UK
- 10-11-2012, 06:58 PM #4
Um, I think may have a setting thats off on my S3 GSam is useing a lot of power. Iam assuming that a setting is off or i havent let it go long enough, i downloaded it this morning. As you can see its 20%, is it because iam using the gsam as a widget?
- 10-11-2012, 07:09 PM #5
Gsam tends to use a lot of power when youre in the actual app. it doesnt use much as a widget.
you had only used 20% battery so did you spend much of that time playing around in Gsam?
GT-I9300, UK
- 10-11-2012, 07:15 PM #6GT-I9300, UK
- 10-11-2012, 07:17 PM #7
GAH! Battery Life Sucks! How to close background apps?
By android acolyte in forum Samsung Galaxy S II SkyrocketReplies: 9Last Post: 01-07-2012, 11:29 AM -
Battery care? How to maintain the battery?
By mdwright1032 in forum LG Optimus SReplies: 3Last Post: 01-09-2011, 06:24 PM -
How to do a battery pull
By jackitoday in forum Samsung Galaxy TabReplies: 5Last Post: 01-01-2011, 03:36 PM -
HTC Checkin Service (or: how to drain a battery)
By obe in forum HTC DesireReplies: 2Last Post: 07-27-2010, 07:47 PM -
How to Close programs .. seem to always run
By MikeB in forum Motorola DroidReplies: 5Last Post: 12-01-2009, 11:50 AM
Reply
