- 10-03-2012, 05:53 PM
Thread Author #1
- 10-03-2012, 06:37 PM #2
Re: Horrible battery on GS3 - phones dies every night! Help!
have you checked to see if there are any apps running in the background? I remember when I checked in the first few weeks of having my S3, I had several apps running in the background (All Free versions of Angry Birds, Words w/ Friends Free, Zynga games.)
- 10-03-2012, 07:11 PM #3
How often are your apps syncing?.....Make them sync every hour not every 10 or 20 min
Whats your brighness level?......keep it at about 15%, screen brightness is usually the most cause for a quick battery drain
Keep your Juice Defender at Balanced and check the settings above and you should be good - 10-03-2012, 07:26 PM #4
1. Start with a factory reset, and don't reinstall anything - see how it goes.
2. Turn off data & WiFi and see what effect each have.
3. Be sure the screen is turned off.
4. (Related to your data connection) Are you in an area where the phone is constantly searching for a signal, or switching between 4G/3G/1X? That'll kill the battery in no time.
5. How many bars on the phone (not data) signal? (or check Settings -> About -> Status and look for Signal strength: how many dbm?)
6. Finally, what's the battery life like when you're not at home? Does it last all day (which it should) when you're out-and-about?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2 - 10-03-2012, 07:47 PM #5
Take it in and get a new battery!
Sent From My EVO 4G LTE! - 10-03-2012, 08:04 PM #6
I had a simple 3D clock sucking my battery .... go to bed with 50% & wake up with a dea phone! Removed that app & I can go to bed with 90% & wake at 84% 7 hours later. You must have a weather app or something banging the f%#% out of your GPS or something like that. BTW, my battery now lests for about 64 hours
Cheers, Jon - 10-04-2012, 06:00 AM #7
id charge it overnght instead lol.
it shouldnt run down that fast when not being used though (unless its north-pole night time lol)
an app is keepin it awake.
get Gsam app, fully charge it then say four hours later see whats been running
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
GT-I9300, UK
- 10-04-2012, 06:22 AM #8
- 10-05-2012, 02:55 AM
Thread Author #9
delete
- 10-05-2012, 02:56 AM
Thread Author #10
Yes, every night before going to bed, I close all running apps by long pressing the home button. Now if there are any rogue apps still running in the background after I close all of them, then I don't know what to do.
I don't know how often my apps sync. But have less than 10 apps installed (list is in my OP). Should it matter?
Juice Defender has always been set to Balanced since the day I installed the app. Never turned it off. Even with JD on, the phone battery died overnight.
I will try factory reset last. It is my last resort.
I usually have about 3 bars of cell signal when I at home.
Funnily, the battery lasts all day when I am up and about during the day. It lasts all day when I am in the office. For some reason it dies at night when I sleep.
I have to try this Gsam app. I didn't know about this app.
What is CPU spy? What does it do? - 10-05-2012, 05:54 AM #11
- 10-05-2012, 01:48 PM #12
the fact its only discharging fast at night is very strange.. there must be a clue in that?
GT-I9300, UK
- 10-05-2012, 03:05 PM #13
I would get rid of Juice Defender and and other task killer type apps. Then install a good battery monitor like GSam. In the morning, check GSam to see what's consuming your battery.
It's always a better idea to figure out what the performance problems are before trying to solve them.
- 10-05-2012, 03:09 PM #14
The s3 bettery is just horrible.
- 10-05-2012, 03:12 PM #15
OP, before you factory reset try a reboot, I have run into this before.
A reboot can sometimes do wonders. That's if you haven't done it already.
Pp.
Sent from the future using Mayan technology. - 10-05-2012, 04:22 PM #16GT-I9300, UK
- 10-05-2012, 04:24 PM #17GT-I9300, UK
- 10-05-2012, 04:26 PM #18
mate is there any difference between holding power button and selecting "restart" versus what someone on here called a soft reset (holding power button in until the phone reboots)?
p.s, aparently taking battery out for >30seconds can fix a lot of simple faults but in this case i doubt it.
plus since the OP has woken up to a dead phone.. that really counts as a reboot eh?
GT-I9300, UK
- 10-05-2012, 04:28 PM #19
It's a horrible bug and there's a while other thread about it. As soon as I leave Disneyland I will post all applicable links.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 - 10-05-2012, 04:32 PM #20GT-I9300, UK
- 10-05-2012, 05:31 PM #21
Pluto slowmo jumped in front of my foot and took it to the snout. What a good dog...
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2Thanked by: - 10-05-2012, 07:49 PM #22
There's another bug caused by a file called "gsiff deamon". go in Settings, Developer Options and check Show CPU usage. If you see "gsiff" running, that's what's draining your battery.
Thanked by: - 10-05-2012, 08:04 PM #23
- 10-05-2012, 08:12 PM #24
- 10-05-2012, 08:20 PM #25
GT-I9300, UK
Horrible battery drain with phone OFF
By starlitfire in forum Inspire Rooting, ROMs, and HacksReplies: 3Last Post: 04-07-2012, 12:39 PM -
Help - MT4G battery goes dead every night
By jtk27 in forum HTC myTouch 4GReplies: 5Last Post: 12-22-2010, 11:07 PM -
Does Wifi Stay On with Phone Off? Battery Loss Overnight
By k3vb0t in forum Verizon Droid IncredibleReplies: 7Last Post: 11-24-2010, 08:52 AM -
Strangely horrible battery life while on standby?
By SR4 in forum AT&T CaptivateReplies: 11Last Post: 11-05-2010, 09:34 PM -
Bad To Leave Screen On All Night, Every Night?
By impaler in forum Motorola DroidReplies: 10Last Post: 08-03-2010, 08:40 AM
Reply
