1. misslessevil's Avatar
    Hi,
    I just got my Galaxy S3 and absolutely love it.
    However I need HELP!
    How can I keep my ringer on and turn off all my other notifications. When I'm sleeping I want to keep my ringer on sound or vibrate and have my texts/emails/all app notifications on slient (not vibrate, SILENT!!).
    How can I do this?!
    Thanks in advance for your guidance!
    -misslessevil
    10-08-2012 10:41 PM
  2. funkylogik's Avatar
    take it youre ex-BB lol.
    there are apps for that but i dont know names.
    im sure someone will help though
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    10-08-2012 11:38 PM
  3. mssca's Avatar
    This is one of the things I missed from my BlackBerry days. Anyway, there is a Do not disturb mode in Jelly Bean OS update. I don't know how it works, but I hope it has a night mode.
    10-08-2012 11:48 PM
  4. funkylogik's Avatar
    sounds good anyway
    10-08-2012 11:59 PM
  5. misslessevil's Avatar
    Jelly bean is that available for the s3?
    10-09-2012 10:44 PM
  6. Tkbredx's Avatar
    LLAMA PROFILES
    One of my favorite apps. Does this and so much more. You can set it for a certain time, only when plugged up to a charger, change the profile at your mother's house, yours, work, etc. Check it out.it's pretty simple to work too
    funkylogik and sargeems like this.
    10-09-2012 11:16 PM
  7. funkylogik's Avatar
    not yet
    http://www.youmobile.org/blogs/entry...-JellyBean-CRS
    10-09-2012 11:18 PM
  8. GSDer's Avatar
    A quick search for 'sound profile' in the Google Play Store turned up a bunch of apps that you may want to look through - this one sounds like just what you're looking for https://play.google.com/store/apps/d...?id=Orion.Soft
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    10-10-2012 01:42 AM
  9. Chillie Hotrebzz's Avatar
    Hey
    I have SIII . For its sound management I'm using a App called Smart volume control.It's working flawlessly on my SIII.Here are the Playstore links
    Lite version :- https://play.google.com/store/apps/d...om_developer#? t=W251bGwsMSwxLDEwMiwiY3ouZGlyZWN0c2VydmljZXMuU21hcnRWb2x1bWVDb250cm9sIl0.
    Pro version :-https://play.google.com/store/apps/details?id=cz.directservices.SmartVolumeControlPlus&feature=more_from_developer#?t=W251bGwsMSwxLDEwMiwiY3ouZGlyZWN0c2VydmljZXMuU21hcnRWb2x1bWVDb250cm9sUGx1cyJd
    12-21-2012 05:57 AM
  10. Chillie Hotrebzz's Avatar
    Hey I got SGS3 too . For my Sound Profile management I'm using this app called smart volume control.It works flawlessly on my device.You better give it a try.It's great app to try out
    They got Free version and Paid version too.So you better try out
    Free Version :- https://play.google.com/store/apps/d...tVolumeControl
    Paid Version :- https://play.google.com/store/apps/d...umeControlPlus
    01-01-2013 10:09 PM
  1. sound profile app
    By Lurch81#AC in forum Android Apps
    Last Post: 05-09-2010, 12:35 AM
  2. Sound Profiles
    By roman08225 in forum Verizon Droid Incredible
    Last Post: 04-28-2010, 09:38 PM
  3. Sound Profiles
    By Justin89t in forum Verizon Droid Incredible
    Last Post: 04-24-2010, 02:40 PM
  4. Sound Profiles
    By passtheboll in forum Android Apps
    Last Post: 03-13-2010, 02:49 PM
  5. Sound Profiles
    By cward0625 in forum Motorola Droid
    Last Post: 11-11-2009, 02:56 PM
