1. lesorkim's Avatar
    Samsung Galaxy S3 phone, Verison Wireless, Andriod 4.0.4, Nova Launcher Prime 1.3.1.
    The "Auto" setting for screen brightness is too dim in several different settings. There have been several threads in the past that lamented this condition, but a solution was never proferred. There MUST be a solution. I thought I read it one time, but upon searching I could not find it. Did I read once that there was a control for turning up/down the "automatic" sensitivity.
    Does Nova Launcher has such an advanced option in it? Is there an add on widget/app to do this?
    I use NFC Task Launcher to put my phones in what I call "modes" like Bedtime, Pocket, Desk, At Home, Car, etc. For each of those I specify a brightness setting - since Auto does not work IMO. The real problem I run into is that regular brightness is fine, then just as I go outside I want to look up something and I can't see the screen hardly at all! I either need a way calibrate AUTO to my liking, install a widget to do the job.
    One other option I have not quite figured out is this; I noticed under the Nova settings you could customize what certian gestures do, so it would be great if I could get a clock wise single finger swirl on the glass to pop the brightness to 100%, or perhaps to have a phone shake do that. "Brightness" does not seem to be one of the assignable options?
    Any ideas?
    Maybe I need to put an NFC sticker in my wallet that says 100% brightness. That way when people see me fish my phone out of my pocket for a call outside and then (when I can't read the display) rub the phone on my *** (for brightness) they will really wonder!!!
    10-10-2012 07:19 PM
  2. jamesino's Avatar
    I am having this identical problem and posted a thread asking the same question recently. I think the best answer I got was that you can download some app that will put an auto-brightness toggle in your notification bar. There are others apps that will allow you to put an auto-brightness toggle widget on your homescreens.
    10-10-2012 07:30 PM
  3. GSDer's Avatar
    My favorite brightness solution https://play.google.com/store/apps/d...playBrightness
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    geekymcfly likes this.
    10-10-2012 10:51 PM
  4. lesorkim's Avatar
    [QUOTE=jamesino;2226843] . . posted a thread asking the same question recently. . .best answer I got was that you can download some app that will put an auto-brightness toggle in your notification bar. [QUOTE]
    {begin smartass mode} That would be great, but I can't see the screen to press any buttons {end smartass mode}
    Can't you just call up the Nova people for me and have them whip up a custom upgrade for me for that custom finger gesture.
    {insert "custom finger gesture" joke here}
    10-11-2012 12:57 PM
  5. smooth4lyfe's Avatar
    I use the Widgetoid app to make quick toggle widgets for my brightness...you can even adjust the auto, and add toggles for almost everything on the phone
    https://play.google.com/store/apps/d...mNvbS5qaW0yIl0.
    funkylogik likes this.
    10-11-2012 01:09 PM
  6. funkylogik's Avatar
    "Display Brightness" is aparently very good for adjusting brightnes "on the fly"
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    lesorkim and evq.003 like this.
    10-11-2012 01:14 PM
  7. crabbz's Avatar
    The built in auto brightness doesn't seem very smart. I've been trying out Lux and it seems much better at automatically adjusting the brightness. Plus you can set your preferred brightness for different levels of ambient light to train it. It is worth a look.
    https://play.google.com/store/apps/d...mx1eC5mcmVlIl0.
    funkylogik and lesorkim like this.
    10-13-2012 04:21 PM
  8. lesorkim's Avatar
    "Lux" looks pretty good. Downloaded it and will test it out. Thanks for the tip
    EDIT 10-16-12 I've been using Lux for several days now and I have been satisfied iwith the auto-brightness function it brings. If in two weeks it is still working as expected I will get the full version.
    10-14-2012 09:47 AM
  9. jneusch's Avatar
    I have been using Brightness Toggle Widget since I got the phone. It has 8 manual brightness levels as well as auto brightness. It works really well on auto. It is VERY sensitive though. If I put my hand in front of the sensor the brightness instantly drops, moving my hand and it comes back right away. It is definitely brighter than the built in auto brightness setting. I never have a problem seeing my screen.
    10-14-2012 10:06 AM
  10. andie93's Avatar
    I've been using Lux for a while. It works better than the built-in autobrightness setting, at least for me. I can't remember how the free version compares to paid, but you can specify your own brightness settings based on the ambient light. It's very easy to do... Instead of messing with the settings right away, I just let Lux do it's thing. Whenever I'd find that it's predetermined setting was too dark or too bright for my preference, all I had to do was open my notifications to pop open the dashboard for Lux, use the slider to adjust the brightness and hit one button to lock in the new setting. After a day or two, it was pretty much perfect. The subzero settings work really well for use in the car at night too.
    10-14-2012 07:52 PM
  1. How to customize the fixed, bottom app dock in the home screens
    By Ophio in forum T-Mobile Galaxy S III
    Last Post: 08-29-2013, 11:29 PM
  2. How to Customize the Epic 4G Touch Lock Screen
    By milominderbinde in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 04-11-2012, 02:06 AM
  3. How to customize the background image for the lockscreen?
    By RnFstRuckHrd in forum Samsung Galaxy Tab 10-inch
    Last Post: 06-23-2011, 02:11 AM
  4. How to turn off the auto shutoff of Optimus Camera?
    By mdwright1032 in forum LG Optimus S
    Last Post: 05-06-2011, 07:18 PM
  5. HOW-TO Customizing the boot script for Gumbo ROM 1.5c
    By Jerry Hildenbrand in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 03-10-2010, 10:47 AM
