- 10-10-2012, 08:06 PM
Thread Author #1
Absolutely atrocious battery life on my S3
All i've been doing is texting here and there with my gf. I have all applications off. I use GoSMS to send texts and i have juice defender running in the background.
Yet, my battery life is poor and horrible. Also I have it set to HSPA+ only, no WIFI, no SYNC on, brightness at lowest possible. Not rooted. Running 4.0.4.
Also during the night, battery life is even worse and i'm not even doing anything. I think it's the alarm clock. I've woken up in the night with mt phone off. Once i actually woke up late cause my phone died and i had no way of waking up
My brother just got the white S3 and he can go days without having to recharge his battery.
Can i fix it? - 10-10-2012, 09:18 PM #2
Re: Absolutely atrocious battery life on my S3
It has to be some apps or widgets. Some weather widgets can drain battery due to gps. You say hspa and no wifi? WiFi is the least battery drain of all..
Sent from my Sprint S3 using AC forums - 10-10-2012, 09:35 PM #3
Check your radio settings. If you have a weak signal, it will kill your battery...even just on HSPA+. I'm only guessing this is the culprit based on your image showing cell standby at the top of the list.
- 10-10-2012, 09:47 PM #4
- 10-10-2012, 09:58 PM #5
I am actually having the same issues and recently downloaded the Juice Defender app. It does help a bit but not too much
i will have to look at other options..! Let me know if you come up with anything
- 10-10-2012, 09:59 PM #6
I agree, looks like your signal/radio has been the problem... A poor signal making the device work overtime can drain a battery fast...
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 10-10-2012, 10:17 PM #7
- 10-10-2012, 11:04 PM
Thread Author #8
- 10-11-2012, 12:05 AM #9
- 10-11-2012, 12:08 AM #10
FWIW, really 85% battery after almost 3 hours isn't that bad... Sure we would like it to be better but it's not really to far off from normal.... First 10% of battery loss always seems to go fast from full charge..
- 10-11-2012, 12:53 AM #11
The things I'd do to still have 80% battery after 3 hours on my HOX.
Sent from my Nexus 7 using Android Central ForumsIf there's no path, we'll make one with these hands!Thanked by: - 10-11-2012, 03:27 AM #12
- 10-11-2012, 03:48 AM #13
- 10-11-2012, 04:55 AM #14
wish iphone users would test an android before committing to one.
if your huge screen has been on for 3hours then 80% is good
EDIT: but judging by your screenshot (finaly got it to load lol) you havent had the screen on much or it would be the main battery drain.
maybe dodgy unit.. maybe an app misbehaving. sorry if i sounded harsh before id seen your screenshot :beer:
try removing juice defender.. im not a great believer in those things
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
GT-I9300, UK
- 10-11-2012, 01:56 PM #15
OP, shut off your battery percentage, install something like JuiceDefender and RELAX. You would have reason to be concerned if it dropped to 85% in the first 5 minutes after the charge.
Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'! - 10-11-2012, 02:02 PM #16
- How often are your apps syncing?
- Whats your brightness level?
- How many apps do you have running in the background? - 10-11-2012, 03:24 PM #17
- 10-11-2012, 04:17 PM #18
- 10-11-2012, 04:23 PM #19
i suffer no hardships doing this -
Battery Tips for Android
1. Toggle off LTE, WIFI, GPS, BT, NFC, Hotspot. Toggle on as needed.
2. Display Brightness - Turn off Auto Brightness and Reduce Setting Bar to Minimum.
3. Sign out of Google Latitude, GTalk, G+, Google Now, and Messenger. Disable Location Reporting/History.
4. Beware of constantly syncing Apps and Bloatware like Facebook, Twitter, News, Non-Push Email, etc. Set Sync interval for every 1 hour or more.
5. Turn off keyboard haptic feedback.
6. Don't use Live Wallpaper. Use dark wallpaper if possible.
7. Set Display Sleep Setting to 2 Minutes or Less.
8. Set WIFI to Always stay on during Sleep if you regularly use WIFI.
9. Turn off vibrate for Emails.
10. Be careful of using too many live widgets.
11. Sync Exchange Emails 30 Days or less.
12. Do NOT use a Task Killer App. - 10-11-2012, 07:54 PM #20
LiveProfile PIN: LPZKCNP5 - 10-11-2012, 08:41 PM #21
My iphone 4 had awesome(like 2 days) battery life. The 4s and 5 (I tried one for 2 weeks) about the same as my s3. Once apple started syncing more things in the background, the battery life suffered. But those are the things people want. You can get several days from dumb phones that don't try to do as much.
Sent from my SAMSUNG-SGH-I747Thanked by: - 10-12-2012, 01:37 AM #22
I just wanted to show off lol... I find that if you limit the apps running in the background it saves a LOT of battery might wanna check that too, as people gave said already
Sent from my Samsung Galaxy S3 Boyyyyyy!- LOVING MY GALAXY S4 EXYNOS BEST I EVER HAD! - - 10-12-2012, 01:59 AM #23
Based on your battery stats you should be able to go a full day on it. If you turn data off when you don't need it you will also save juice.
Also just plug it in at night, and problem solved.
Edit: your standby percentage is a bit wacky though. I just checked my phone and after 9+ hrs. My stand by is at 4%.
Sent from my SGH-T989D using Android Central ForumsLast edited by badbrad17; 10-12-2012 at 02:20 AM.
Android Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 10-12-2012, 02:22 AM #24
Android Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 10-12-2012, 04:21 PM #25
Battery life on new S3 not so good
By luqman24 in forum Samsung Galaxy S3Replies: 59Last Post: 01-16-2013, 12:23 PM -
A question about very short battery life on my new Galaxy Nexus..
By Withacupofcoffee in forum Google / Samsung Galaxy NexusReplies: 18Last Post: 07-16-2012, 12:43 PM -
increase battery life on my htc sensation 4g
By htc sense in forum T-Mobile HTC SensationReplies: 0Last Post: 06-21-2012, 07:39 AM -
Hows your battery life on international s3?
By fwdkiller420 in forum Samsung Galaxy S II SkyrocketReplies: 1Last Post: 06-14-2012, 06:06 AM -
My mother says she's getting worse battery life on Gingerbread...
By MowDownJoe in forum Motorola Droid XReplies: 9Last Post: 06-23-2011, 04:43 PM
Reply
