1. DroidMomma30913's Avatar
    I heard that TecTiles can be set activate car mode (or driving mode) so you can put one in your car. How do I do that? I know how to program them, but I can't figure out how to set one for car mode. Help, please?!
    10-11-2012 11:20 AM
  2. Srambo217's Avatar
    I did some research for you. I don't see a Car Mode toggle in NFC Task Launcher. You can launch Tasker profiles with NFC Task Launcher but I don't see a Car Mode toggle there either.
    Seems like most people enter Car Mode from their status bar pulldown or from S-Voice.
    You could make an Atooma (or download a user made) profile that auto launches when you're phone is in driving conditions. Check out this app, it's free in the Play Store.
    Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
    10-11-2012 02:24 PM
  3. GSDer's Avatar
    Is this different than what you're looking for? TecTiles Help?-uploadfromtaptalk1350019733456.jpgSent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    10-12-2012 12:29 AM
  4. Srambo217's Avatar
    Is this different than what you're looking for? Click image for larger version.
ID:	41043Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    Are Car Dock / Car Mode the same thing? I don't use either.
    10-12-2012 02:23 AM
  5. Craigiemk's Avatar
    What app is this?
    11-03-2012 07:34 PM
  1. HELP! Need to get G1 Working or Dieter Will Kill Me!
    By Rene Ritchie in forum The Android Central Lounge
    Last Post: 06-02-2013, 03:17 PM
  2. My Turn - Help Dieter with the G1
    By Dieter Bohn in forum The Android Central Lounge
    Last Post: 04-26-2013, 07:08 AM
  3. Round Robin: Help Jennifer with the G1!
    By Jennifer Chappell#CB in forum The Android Central Lounge
    Last Post: 12-14-2009, 08:59 PM
  4. SOS: All G1, Gmail, Gtalk contacts disappeared. Please help!
    By android007 in forum General Help and How To
    Last Post: 03-17-2009, 04:28 PM
  5. SOS: Please Help: IMport SMS from XML file to G1
    Last Post: 02-06-2009, 11:15 AM
