Please tell me why the S3 is better than an iPhone.
For the last few of months I have been using a GS3. I am a long time iPhone user. But after three month, I am close to deciding that I miss my iPhone too much.
Before I sell my GS3, I want to make sure that I have given it a fair chance to win me over.
I can see why the S3 initially impresses. It has a large screen (which is the main reason I wanted to try it in the first place), NFC, facial recognition. But I haven’t found these things to be as big a deal as I pictured.
So can anyone tell me what have I missed? What is it that makes you guys choose the S3 or Android over an iPhone? Thanks in advance...
Re: Please tell me why the S3 is better than an iPhone.
Here's 50
[Only registered and activated users can see links. Click Here To Register...]
Sent from my SCH-I535 using Android Central Forums
You can customize the look, more robust integration of apps, open system, notification system blows iOS out of the water, not chained to itunes and one ecosystem, micro USB so no need to keep buying new plugs and chargers, screen size, alternate keyboards, etc....
Do u need more? These are just a few.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
I can't speak for the s3 but for me it's all about customization. On android you can change almost every aspect of the UI, even make it look like Iphone if that's your thing. while your more limited in that respect on Iphone.
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ baseband
I cant tell you if the S3 is better than an iPhone no more than someone over at iMore can tell you that the iPhone is better than the S3. Why?
It comes down to the individual... your expectations, how you use your phone and other personal nuances and preferences.
There is no "best phone" for everyone, there is only the best phone for you.
Unless someone knows you and how you use your phone, they are only projecting their own preferences on you.
Go to a store and spend at least an hour looking at both phones, form your own opinions... and not someone else's.
If you like the iPhone better, go back to that. Technology only matters if it works for you.
Good luck!
S3 sucks, if it's on ATT I'll buy it. :D
If you haven't figured out the answer to your question in 3 months, I'm sure none of us will in 5 minutes. I + any comment that states that everyone has different preferences and it's always comes down to that single idea. Just because I like the s3 doesn't mean Joe blow will. Just as I will not like what Joe blow likes. Well unless he or she has no clear mindset or identity of what he desires its very easy to convince someone of the best product. But with all that said I personally love the size, audio output and design. Other than that it's just an ordinary phone to me.
"may the odds be in your favor"
Its difficult to switch platforms. Especially when you did t particularly have an issue with platform you are leaving. I have never had an issue with any iPhone that i have owned. But I continually leave it behind due to either things that I get from Android devices. I think that the OP will miss the S3 if he or she were to vet rid of it.
Quote:
Here's 50
I was about to post this lol but its way better...Ive been with the iPhone since the 3 up until the 4S and I can say it
- More customability (Home Screens, Themes, Icons, fonts, Voices, etc.)
- you can connect your external Hard Drive to it and import and export to and from your phone
- You can connect your PS3/X360 controller to it and play games
- NFC abilities (Unlock your hotel room door with ur phone)
- TRUE HD screen, the iPhone 5 is NOT a true HD screen as tested
- LED Notification alerts
- More camera effects and features
...I could go on
I haven't read everything here. But I will say this....the gs3 can do everything the iPhone can and more....so..yeah. but it just may not be the phone for you. IPhone may just be your thing. And If that's what works for you. Go ahead and use it my friend.
True HD is 1080p...so no phone does True HD. Also you wouldn't be able to tell the difference between the iphone 5s resolution and the S3 resolution and anyone that knows about displays will tell you this. Now you'll see the difference in the display since the SG3 is pentile and uses AMOLED display and the iphone 5 uses IPS LCD screen. Test have shown the iphone 5 display is better and so has other benchmarks test.
To the OP....I just prefer to stay with android and I know when Apple has the more powerful device and will admit it..which it does. The iphone 5 is a beast of a phone and if you miss it then I would go purchase it, but you'll probably come back to android next year when the android devices are faster then the iphone 5 and you'll be stuck in a cycle of not being happy and keep changing devices.
He would be locked in with the S3 so regardless he would have the outdated device. Not the right way to think about it. I switched from the S3 to the iPhone 5. Applications are much smoother and its faster in my opinion. Only thing I miss from my S3 is the large screen (been using android for 3 years).
Sent from my Xoom using Android Central Forums
It's better because I like android more than ios.
That's all I can chip in. If your opinion is ios is better go for it.. It's preference.
Sent from my Sprint S3 using AC forums
I can only only give you my personal reasons, and they may not fit your criteria.
I like the ability to share files wirelessly whenever, wherever and with whom ever i chose no matter what phone the individual may have. (exception being iphone).
I like the ability to customize my phone to suit my liking as per this tread.. [Only registered and activated users can see links. Click Here To Register...].
I like the ability to view video and web pages on a big screen.
I like the ability to transfer files to and from my phone to my computer quickly and to exactly where i want without having to go through and application.
I like the ability to have led notifications.
These are just a few of the reason why i prefer the S3. In short i just love the flexibility i get from android. But, as i said those things may not matter to you. the Iphone is a great phone. No doubt about that, but it simply doesn't suit me. It all comes down to what you want from your phone. So just chose what works for you and all is good.
lets just cut the sh*t right here.
I moved to android from an iphone 3g ages ago, first android phone was a desire hd, then s2 now s3, overall android is more user freindly and customisable, I totally get that this is personal preference (each to their own) but i cant stand ios.
the reason for upgrading to s3 was the screen, its a thing of sheer beauty, it destroys the poor s2 screen in a very bad way, now the reason for having a smartphone is browsing,gaming,movies,you tube etc, all these are better on the 4.8in s3 screen that the iphone 5's little 4in display lol, as for people ranting on about the iphone build quality, yes its better but trust me, when your gaming etc etc, you dont sit there worrying about the build you'll be far to busy ingrossed in that gorgeous 4.8in screen.
I could never go back to a 4.3in let alone a 4in screen, next time your talking to someone with an iphone, pull your s3 out and put it next to their iphone, You can just see the poor look on thier face as the little 4in display pales in comparison, even better show them shadowgun's graphics, give it a week they will be listing their apple on ebay.
i feel sorry for all the people sucked in by the apple hype, they really are missing out.
Here's my experience. I had an I phone 4 for a year and loved it. But when I saw the S3 I knew I had to try it. But I kept missing my Iphone so I musta switched back and forth three times before finally settling on the S3. My favorite feature is the pop up video. I love watching my favorite movies while doing other things on the phone!! So in order to get my fix I simply kept the S3 and decided to get an ipod because we all know the app store has way more to offer then Google play. Keep the S3 and get yourself and ipod!!!!
I'm the biggest Apple geek amongst anyone I know and probably one of the most heavily invested in iOS, and the Apple ecosystem in general(still am) With that being said, for me it's all about diversity. While the iPhone really shines with its ease of use, it really starts to show it's age with it's aging OS. The static row of icons spread amongst several home screens has really become long in the tooth. While widgets ultimately don't seal the deal for me, the fact that you can customize the S3 to look however you want is the real deal breaker. Download Go Launcher, and you can regain the looks of your iPhone instantly. The size of the S3 display while keeping it's portability won me over on the first day. With that being said, there's nothing my iPhone can do that the S3 can't, but unfortunately there's plenty the S3 can do that the iPhone can't. No native YouTube, and Google maps has become a thorn in my side on my iPad. Those two apps are sorely missed on my iPad but beautifully functional, and present on my S3.
In the end it all comes down to personal preference really. I still really love iOS on my iPad, and love the looks, and overall feel of the iPhone 5. However for me just felt like it's becoming more of the same with each release. Best of luck in choosing!
No, you tell us. What am I missing that someone would choose an iPhone? Why choose an iPhone over an S3?
Is it the tiny screen? Being locked in to iTunes? Being limited in what customization you can do?
If you have good answers, then by all means go to an iPhone.
Here's my take on this: When I went to upgrade my phone earlier this week, I ended up choosing the GS3 over the iphone. Why? Because in my opinion, iOS is painfully boring. It's also too locked down for my taste. I wanna be able to fully customize a phone that I paid for. I can't do that with an iPhone. I also don't wanna be locked into using iTunes, which in my eyes, kinda sucks. Videos and web pages look so much better. If you miss the iPhone so much, then go ahead and go back. It seems like you've already made your mind.
I've used both Android and iOS devices and I could never see myself getting an iPhone again after seeing how boring it is compared to the Android OS. If you want something basic and don't care much for tinkering then iOS is better.
This is from me, on my EVO 3D.
threads like this are really hard for me to reply to as even when the first ipod was released, the whole trendy thing didnt appeal to me and even back then i didnt like the idea of itunes, maybe thats the type of person i am, i dont want to fit in and (i know this sounds like a terrible cleche) "follow the herd". id rather have had a generic mp3 player.
id say if you arent in any way geeky or passionate about technology and just want it to work for you without you making it work for you then get another iphone.
its not about ip5 vs s3 imo, its android vs ios and s3 is arguably one of the best androids yet.
neither is right or wrong, its just what type of person you are.
all i ask of people is not to buy an s3 expecting a big iphone and then moan about it :)
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
Here is a ton of info on just what is different between iOS and Android. Watch all the videos and you will be amazed...
...and they say that I phones are just easier and more simple to use!....
#1 of 5... [Only registered and activated users can see links. Click Here To Register...]
#2 of 5... [Only registered and activated users can see links. Click Here To Register...]
#3 of 5... [Only registered and activated users can see links. Click Here To Register...]
#4 of 5... [Only registered and activated users can see links. Click Here To Register...]
#5 of 5... [Only registered and activated users can see links. Click Here To Register...]
Sent from my Innovative Galaxy S3
Last summer, 2011 I switched from my then iPhone 4 to a Droid Charge. I tried really hard to like android, but I had been using an iPhone for about a year and a half and I really liked it. My initial motivation was screen size and 4g LTE. After 4 months with the Charge I couldn't wait to get back to the iPhone. I made the switch when the 4s came out, even standing in line at the Apple store. I use iTunes and have Macs at home so the iPhone really is the right phone for me.
Fast forward to this summer. I see the ads for the GS3 and like what I see. I start my research, look at the phone in the store a couple times, then decide to pull the trigger. I bought it at Best Buy and am a premier RZ member, so I had a 60 day return policy since I had to pay retail. I figured 60 days was long enough to see if I would miss my iPhone again. Funny part of the story is that day number 60 was the day the iPhone 5 was announced and I didn't even think about heading to BB after seeing the announcement.
For me it is about several things:
1 screen size is a big one
2 screen customization- I love being able to change my home screens to fit my mood, taste, or whatever other reason
3 flexibility- I still sync with iTunes every night with iSyncr. But, I can get music from other sources, back up in other ways, get apps from several different sources, etc.
4 SD card and removable battery are also nice and add additional flexibility. I used to have to keep my 4s on the car charger a lot. I travel for work and use my phone to stream music, pandora, etc. With the SD card I effectively doubled my system storage for $30 versus $100 with the iPhone. I bought a bigger battery and now I never have to charge until the end of the day.
5 micro USB. Way cheaper and easier with this.
The GS3 is not without its quirks, but all phones have some issues. I was very pleased at how much better the GS3 was over the Droid Charge last year. ICS is also a huge leap versus Froyo, which was on the Charge.
I understand your dilemma because that's where I was last year. I made all the excuses in my own mind why iOS was better. Even when I got the GS3 I only planned on trying it out, knowing full well I would return it. I was really surprised at how much I liked it once I had some time with it. I was more tolerant of the differences in the OS's than I was last year, which helped. If I was forced back to iPhone I wouldn't be devastated, but I would be disappointed. The iPhone is a great phone with a great OS, however I think Android gives me more of what I like and expect in a smart phone.
Good luck with your decision.
Between these 2 phones is pretty obvious the gs3 is better. Facts speak for themselves.
Now would you like it more is the question for you.
Better phone isn't always the phone you like more.
Example, the Galaxy S3 is a better phone than the one x, but a lot of people like the one x more
The galaxy note 2 is clearly better than the Galaxy S3, but I still like my gs3 more due to it being just the right size for a phone and still fast.
Pick what you like more, if the same ol same ol and not having new technology works for you, go with the iPhone 5 (which would have been impressive 2 years ago)
If you like to fix things exactly how you like them, the option to choose, having the latest technology, working maps, no tint on your camera, an excellent sized screen,NFC, motion control, voice control (download assistant,s voice sucks), and the ability to install any app you want without voiding your warranty, stick with the Galaxy S3.
no one else can tell you what you would like more
Sent from my SGH-T999 using Tapatalk 2
