galaxy 3 indicator incons an eys comes up what is this icon
worwig
990
50
Likely, in the display settings, you have 'smart stay' turned on.
That turns on the front camera for a few seconds and tries to determine if you are looking at the screen. It will then keep the display turned on if you are.
GSDer
8,471
15
Not that this feature works for beans - most of the time, I'll see the Smart Stay icon show up in the Notification bar, after which the screen turns off anyway. I contacted Samsung support and they wanted me to do a factory reset so I just gave up on that resource since it's never worked properly even after all of the other factory resets that I've done.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
funkylogik
9,637
111
i find it pretty useless too mate same as most of the gimmicks they used to promote the phone
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
tress
