Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Like Tree26Likes
    Default Just switched from iPhone need help
    I think I got most things covered, however there is one item I can't seem to find an answer to. How do I get pictures from iPhoto to the S3. I can export them a group at a time, but I would love something where I could select a whole bunch (I have them all arranged in albums) to export and eventually sync. I hope I don't need to go via the "cloud" since my total library is 65GB and I only want to select a portion at any given time.
    Thanks
  2. #2
    Default Re: Just switched from iPhone need help
    I would assume dragging/dropping the images to you're external SD card would work. Honestly, using a cloud like Google Drive would be a lot easier.
    Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
  3. #3
    You would think one of us would sticky a thread like this by now huh? Someone should really try and make an user guide for ex iphone users if they have the time because we literally get this same topic atleast 4 times a week
    I wld do it.. But I'm too lazy, lol
    I used to use physical buttons, and then I found button savior
    -S. T. C
    Sent from my rooted, debloated CM10 jelly bean 4.1.2 Samsung Galaxy S3 #LikeABo$$
    Android is a tune up sports car with custom interior, sound system, and IOS is a stock model benz
    I use Android, because unlike IOS, i keep my apps in app drawers, and not infinitely cluttered homescreens
    Thanked by:
    Tkbredx likes this.
  4. #4
    Quote Originally Posted by rteichman View Post
    Thanks
    I would try doing it via pc and copying images between both devices, probably the fastest solution
    -S. T. C
  5. #5
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    Quote Originally Posted by Soundtrack to Chaos View Post
    -S. T. C
    oh man you honestly wrote EXACTLY what i was thinking.. especialy the "im too lazy" part
    it would be very useful given the amount of converts
    back on topic, would it be any easier usin an sd card+reader?
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    GT-I9300, UK
  6. #6
    GlennTX's Avatar
    Posts
    Global Posts
    52 Global Posts
    Yea after you install Kies, then you can drag and drop them in whatever folder you want (phone or SD).
    BB 9000 > BB9800 > Samsung Galaxy S3 (AT&T)
  7. #7
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    be warned... Kies is a pr*ck of a programme!
    GT-I9300, UK
  8. #8
    There is another program with 2 way sync that's works well. Syncmate will do what you want it to do. It will also sync iTunes music. It is not a free app though. You need to install it on your Mac, then connect via USB or through wifi.
    Samsung Galaxy S4 - AT&T
    Samsung Galaxy Note 10.1 LTE - VZ
    Galaxy Note 8
    Apple iPad3 - 64GB LTE
    funkylogik likes this.
  9. #9
    Tkbredx's Avatar
    Posts
    Global Posts
    1,839 Global Posts
    ROM
    TeamSonicFreeGS3 v9.1
    No recommendation for drop box yet you guys? Shame on y'all lol.
    That but it probably would be easiest to plug phone in computer as usb. Copy iphotos over to galaxy s3
  10. Thread Author  Thread Author    #10
    Thanks, but my issue is not getting the pictures on to the S3, it's finding a convenient way to get them out of iPhoto :-) I have already got some test pictures on, but I'll look into the Syncmate.
    On a side note to any other converts, and please don't flame me. Do you get the impression that the iOS and the Apps are a bit more polished on the iPhone? It's small things like visual voice mail integration and number of messages displayed. Even the facebook app seems "cleaner". I'm just starting and there is a lot I like, maybe I'm just too used to the iPhone after so many years.
  11. #11
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    lol ive never had an apple phone but think its kinda common knowledge that the apps are more polished (maybe thats where the money is?) but i think android will get there and u get a lot of quality free stuff.
    facebook for android is a disgrace btw lol, i prefer to use m.facebook.com on the browser.
    they really need to build a new app from the ground up instead of persisting with that piece of crap lol
    GT-I9300, UK
  12. #12
    -S. T. C
    LOL. I was browsing AC and saw this. I was like.... Heeeeeey Lookie here.
    Apple User's Guide to Android
    Android Evangelist
    HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4
    Thanked by:
  13. #13
    Quote Originally Posted by funkylogik View Post
    I agree 100%. On a the tablet it is completely useless even in the browser it's lame. I heard they are working on a new one.
    Android Evangelist
  14. Thread Author  Thread Author    #14
    Quote Originally Posted by badbrad17 View Post
    I looked there. My question I guess was not well stated and maybe I should check on an Apple forum. However I figured there were enough switchers to ask here. My question is not so much how to get pictures onto the phone, I know that. Its how to get pictures OUT of iPhoto in groups. I saw one recommendation about putting my iPhoto library on dropbox (which I have along with google drive and the MS one). My question, before I spent the money to upgrade dropbox to hold all that, is will the phone be able to access the iPhoto library. It's really a database with a long list of unintelligible files.
  15. #15
    I have never used iPhoto, but you may want to consider making your own cloud server. I follow this guys youtube channel and loved this idea. I think it would be very affordable and give you infinite options.
    Sent from my SGH-T989D using Android Central Forums
    Android Evangelist
  16. #16
    -S. T. C
    Perhaps an "Ex iOS user FAQ" haha
    LiveProfile PIN: LPZKCNP5
  17. #17
    I just switched as well and am wondering if there is an easy way to move an email to google drive from the phone? Please? Anyone? Thanks!
    Sent from my DROID RAZR HD using Tapatalk 2
    Douglas Wilson
  18. #18
    Quote Originally Posted by douglaswilson View Post
    I'm using Aqua mail and you can do this in this app. Open the mail message. Click menu select copy/share when menu opens select Google drive.
    Android Evangelist
  19. #19
    Any suggestions on something to make my galaxy s3 sync to Facebook like my iPhone did? It pulled in pictures and information even if I wasn't friends with them- they were just in my phone book. I miss that feature on the iPhone. Thanks.
    Sent from my iPad using Tapatalk HD
    Douglas Wilson
  20. #20
    I'm not sure what you mean. You want to have people you don't know automatically sync with your contacts?
    Android Evangelist
  21. #21
    No, not people I don't know.... People in my address book that I'm not "friends" with.
    Sent from my iPhone using Tapatalk
    Douglas Wilson
  22. #22
    I have found that Facebook sucks on both os's. One thing about Kies is that it will find all you files and I do mean ALL. Problem is it finds all the useless gifs, mpegs, jpegs and everything else that you have to sift through. Won't group though like iPhoto and iTunes, something I miss.
    Not sure about FB though, when I installed the app and I signed in everything was right including my friends list.
  23. #23
    When you go into your sync settings you can sync with FB and in your FB settings within the app you can choose how you want to sync your contacts.
    Android Evangelist
  24. #24
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    yeah as brad says. settings, accounts and sync, add account, facebook (bit diff on ICS n JB but youll get it)
    GT-I9300, UK
  25. #25
    Quote Originally Posted by Solutions Etcetera View Post
    It is not an impression. Apple writes software to SELL hardware. They are in control of the both the OS and the Hardware, and their developer resources are vast. Their flagship apps have no equal on Android currently. And since they are also in control of the marketplace, they hold third party developers to a published set of interface guidelines. Not to say there isn't junk in the App Store as well, but it is usually prettier, more polished junk (c;
    And frankly, the dev tools and OS are quite a bit more polished as well (but Android is starting to catch up), as should be as Apple is in control of everything. It is a shame they have chosen to lock it down so, but it is working for them big time so it is not going to change. In fact, the sandboxed mindset is finding its way into the desktop Mac OS as well, which is really unfortunate for folks who like to get their fingers between the fan blades, although it does have undeniable security advantages.
    Google needs to step up in some areas of the core system, IMHO. Things like full device backup and "find my iPhone" require access to files and hardware that should be restricted to the core OS. Yes you can root and hack to get to some of this satisfactorily, but you shouldn't have to as these are features that ever user should have, without having to hack and compromise security.
    I use both platforms and am a "fan" of neither as both have pros and cons, but currently the app experience is better on iOS. I am confident that Google will continue to make progress here so long as users support them while still holding their feet to the fire for improvements that are necessary, instead of making light of them solely due to denial or fanboyism. Without user feedback, little will change.
    I would disagree with this. I found my app experience to be much better on Android than it was on iOS but that's gonna vary from person to person.
    This is from me, on my EVO 3D.
  1. Replies: 2
    Last Post: 04-23-2011, 11:10 AM
  2. Just switched from iPhone... couple of Q's.
    By putty in forum Verizon Fascinate
    Last Post: 09-12-2010, 08:14 AM
  3. May switch from iPhone 4, need contacts
    By agreer in forum AT&T Captivate
    Last Post: 08-03-2010, 07:00 AM
  4. Replies: 3
    Last Post: 06-14-2010, 12:44 PM
  5. Just got my Incredible, switching from iPhone.
    By stickstickly in forum Verizon Droid Incredible
    Last Post: 05-06-2010, 07:19 PM
