Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By noaim
    Default Question about LTE
    So this may be a simple question but I wanted to make sure
    Say I use my GPS and one day I use just 4G and another day I use LTE, but go the exact same distance each day
    Will the LTE use more data than just 4G because its faster? Or will they both use the same amount of data?
  2. #2
    noaim's Avatar
    Posts
    Global Posts
    9,439 Global Posts
    Only thing that changes is the speed you get the information you are still just downloading the same amount of data! You may see worse battery life though on lte
    Sent from my iPhone 5 using Tapatalk
    Thanked by:
    smooth4lyfe likes this.
    Default Re: Question about LTE
    Ahh got it double thanks! Thanks for the quick reply and the confirmation!
  4. #4
    noaim's Avatar
    Posts
    Global Posts
    9,439 Global Posts
    Quote Originally Posted by smooth4lyfe View Post
    No problem!!
  5. #5
    EndlessDissent's Avatar
    Posts
    ROM
    CM10
    FYI, since you seem to be misinformed (I'm guessing by a Sprint rep), LTE is 4G. Were you comparing LTE and Wimax? The GS3 isn't compatible with Wimax, so the only 4G you'll ever get is LTE.
  1. Question about LTE
    By ibejack96 in forum AT&T
    Last Post: 08-22-2012, 11:04 AM
  2. Quick Question About ATT LTE and HSPA+
    By plmiller0905 in forum AT&T Galaxy S3
    Last Post: 07-09-2012, 04:47 AM
  3. Question about LTE
    By j0hn13y in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 02-20-2012, 06:32 PM
  4. Upgrading to Bionic! Question about 4G LTE?
    By tbssawd07 in forum Verizon
    Last Post: 09-19-2011, 03:19 PM
  5. Questions about android handsets
    By mills1540 in forum The Android Central Lounge
    Last Post: 08-16-2009, 09:23 PM
