Results 1 to 13 of 13
    Default Extended Battery and Otterbox?
    Anyone know if any extended batteries fit the GS3 inside an Otterbox Defender? I just switched from a Droid X.. in which I had an extended battery and the otterbox... and it fit just fine. Curious if anyone here has done this and what size battery?
  2. #2
    Default Re: Extended Battery and Otterbox?
    I don't really think it's possible because the case that goes inside the silicone is very tight and can only fit the phone itself with, normal battery
    There is a small square like box inside the case, it's probably no thicker than a 1/3 of an inch long so maybe if you can cut that out, then maybe you could get the case to close with the extended battery in it, but idk
    I used to use physical buttons, and then I found button savior
    -S. T. C
    Sent from my rooted, debloated CM10 jelly bean 4.1.2 Samsung Galaxy S3 #LikeABo$$
  3. #3
    Quote Originally Posted by cyberchief View Post
    I have the same issue. I wish I would have held off on the OB. Seidio has an extended battery case / holster combo for their extended battery. I have read, but not tried, that you can call them and order an extended battery door that will work with other batteries, then use the Active case / holster.
    I am considering trying this, then selling my OB. I am also considering a switch to the Razr Maxx HD for the better battery with a thin design. I have held the Maxx HD and its thin size is impressive. This is the main reason I haven't called Seidio and gone that route, yet!
  4. #4
    Tkbredx's Avatar
    Posts
    Global Posts
    2,123 Global Posts
    Carrier
    TeamSonicFreeGS3 v9.1
    I think a couple people over at xda did the mod. Try over there man.
  5. #5
    I just purchased the Hyperion extended battery and case combo on Amazon for $35 together and I couldn't be happier. The extended battery does make the phone much bigger and heavier, but I don't mind the added bulk considering the insane battery life im getting.
  6. #6
    Quote Originally Posted by bigjotto316 View Post
    How is the case working out for you. I'm so tempted to buy one but I'm thinking of nodding a extra otterbox I have
    "all animals are created equal but some animals are more equal than others" animal bylaws- animal farm
  7. #7
    Yeah same here, I have my Hyperion extended battery and using this case which is cheap but is also pretty good! Looks pretty sleek with the black as well. It fits well and all holes are accessible. It covers the mic a lil bit but it doesn't affect the calls
    http://www.amazon.com/Samsung-Galaxy...cUvbUpU2258467
    Attached Thumbnails Attached Thumbnails Extended Battery and Otterbox?-418l1xp4jql._sl500_aa300_.jpg   Extended Battery and Otterbox?-418l1xp4jql._ss400_.jpg
  8. #8
    I had the same question about the extended battery and the OtterBox case. I ended up modding the case and getting it to work fairly well. Just uploaded a video of the finalized case.
  9. #9
    Quote Originally Posted by hcex98 View Post
    That's a great mod but I'm hesitant about leaving my back exposed.
  10. #10
    Can't that damage the battery if dropped on its back?
  11. #11
    True. The biggest thing that would be a problem would probably be the weather. Dust isn't really an issue. At least it hasn't been yet.
  12. #12
    Quote Originally Posted by smooth4lyfe View Post
    It's possible. I've dropped mine since I've modded it, while not directly on its back, but still haven't had a problem. The SIM and all the other components are still hidden behind the plastic case.
  13. #13
    Quote Originally Posted by jneusch View Post
    I've had very good results with all the accessories I've bought from Seidio over the years, for many different phones. High quality and great support. Just ordered the extended battery (with NFC) and the extended case/holster, should have it all by the end of the week. As light and thin as the S3 is, I'm thinking the extra weight & thickness (along with the Seidio "soft touch" slightly rubberized finish on the door) may actually feel better in the hand. Will report here after I get it all and use it for a bit.
  1. Extended battery and Otterbox case
    By KeepOnSingin in forum Verizon Galaxy S3 Accessories
    Last Post: 08-10-2012, 10:23 PM
  2. Want and extended battery and belt clip combo
    By bradyapba in forum Droid 2 Accessories
    Last Post: 05-02-2011, 02:37 PM
  3. FS: Droid X WITH extended battery and cover
    By NickB2005 in forum Marketplace Archive
    Last Post: 03-28-2011, 09:34 PM
  4. Replies: 21
    Last Post: 09-03-2010, 11:15 PM
  5. Extended Battery and Case
    By CRKhead in forum Incredible Accessories
    Last Post: 05-10-2010, 01:47 PM
