Results 1 to 11 of 11
    Davyo's Avatar
    Posts
    Global Posts
    127 Global Posts
    Default Can't view photos on PC with USB connection to GS3,,, help please
    When I hook up my iphone 5 or any of my other phones or cameras to my PC via USB conection to transfer pictures to my PC I can see the thumbnails of the photos on ALL my devices except for the GS3,,,, the GS3 just shows generic thumbnail icons when opening the DCIM folder,, no images.
    It's quite a pain when you only want to select certain photos to copy to your PC.
    How and what is the fix for this ?
    Thanks in advance
    Cheers
    Davyo
  2. #2
    Default Re: Can't view photos on PC with USB connection to GS3,,, help please
    Try uninstalling the the SG3 device driver and plugging your phone back in letting it install again and see if that helps.
  3. #3
    I see the same thing as the OP. Third phone, each one was the same. I've uninstalled the device driver a few times.
    Blessed are they who can laugh at themselves, for they shall never cease to be amused.
    AOKP 4.2.2 Milestone 1
    Davyo's Avatar
    Posts
    Global Posts
    127 Global Posts
    Quote Originally Posted by trucky View Post
    Glad to see some one else post about the same issue,,,,,, I have seen other mentions of this issue as well on other sites and the advise was to use Samsung Kies, which also did not resolve the issue.
    It is odd and frustrating that photos can't be viewed on the GS3's DCIM folder via a USB connection to a PC.
    I have also read that Jelly Bean does not fix the problem either.
    There has to be a fix, it sure would be great to find out what that fix is.
    Cheers
    Davyo
  5. #5
    As apollooff320 alluded to, I think it has to be in the drivers. I have a sync program I use to synchronize files and folders. When I plug in any other USB device it automatically sees it and syncs. It can't even see the S3. And Kies is crapola. I've installed every new version that comes out and have not had success with any of them. I can install and use an S3 Toolkit is use to root and install CWM and it works perfectly. I do a fresh install of Kies and it just tells me "Not valid for this phone". It should be simple.
    Davyo's Avatar
    Posts
    Global Posts
    127 Global Posts
    Anyone else have any ideas on how to fix this issue ?????
    Thanks in advance
    Davyo
  7. #7
    Not sure if this would help.
    Sent from my SCH-I535
  8. #8
    Quote Originally Posted by skennelly View Post
    I tried that app and wasn't able to get good results. I might not be using it right. The instructions are kind of sparse.
    Davyo's Avatar
    Posts
    Global Posts
    127 Global Posts
    This whole issue is so odd,,,,, Samsung puts a great camera in the S3 but then hobbles it with not letting you view the images on your PC,,,,, I don't get this at all,,,, this is for sure one area where my iphone 5 wins over my GS3.
    I wonder if Samsung is aware of this very stupid mistake on their part and if they plan to put out a fix/update,,,,, as I mentioned before Jelly Bean also has the same issue,,,,,,WTF Samsung ????
    Cheers
    Davyo
  10. #10
    Yeah same here, not sure why its like that (Maybe a privacy issue?)
    But you can double click on one of the photos to see the picture with your Photo Viewer on your computer, then just see them all from there (Clicking left/right on the keyboard to go from one photo to the next)
  11. #11
    walcolm's Avatar
    Posts
    Global Posts
    748 Global Posts
    Folks,
    The gs3 doesn't register itself as a memory card when connected via usb so it doesn't give the same latitude you get from one
    It was like that on ics and still like that on jb
    Sent from my GT-I9300 using Android Central Forums
  1. Remote view/control RAZR on PC via USB (non-root)?
    By ManiacalMF in forum Droid RAZR
    Last Post: 09-05-2012, 03:29 PM
  2. Memo pad/note pad that I can create notes on pc with first
    By lovin2act in forum Android Applications
    Last Post: 07-20-2012, 11:30 AM
  3. How do I view 3d photo on pc?
    By tommymsw in forum HTC EVO 3D
    Last Post: 03-22-2012, 04:29 PM
  4. Frustrated with USB connection to my PC
    By jerryduncan52 in forum Droid Bionic
    Last Post: 10-30-2011, 03:37 PM
  5. Can't connect HTC EVO to PC with usb cable
    By scramer in forum General Help and How To
    Last Post: 08-07-2010, 12:08 PM
