Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Ceetar
    Default S3 not recognised as a media device
    Hi there, can anybody help me get my samsung galaxy S3 to be recognisable to a pc as a media device rather than just a camera. When i plug it into the pc it sees a camera. I have set the phone to be recognised as a media device with no joy. I can access all the menus in the phone it seems on the pc but cant transfer any media which is very frustrating. ANy help appreciated, thanks.
  2. #2
    Default Re: S3 not recognised as a media device
    Update the drivers
    "all animals are created equal but some animals are more equal than others" animal bylaws- animal farm
  3. #3
    Use Wifi File Explorer and never look back.
    Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
  4. #4
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    Quote Originally Posted by jaj6503 View Post
    does that work with a wifi laptop and wifi phone but no home broadband or wireless router?
    (is that my stupidest question yet?)
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    GT-I9300, UK
  5. #5
    Quote Originally Posted by funkylogik View Post
    Not a stupid question dude, but yes you do in fact need an active router/modem.
    Thanked by:
  6. #6
    To the OP when your phone is plugged in to the computer. Drop down your notification Window and there should be an option to switch from camera to media device. I'm pretty sure that is how. On my old dinc there used to be many options for charge only, mass storage etc. Now there is only camera and media device.
    Hope that helps.
    Sent from my Samsung Galaxy S3 using Android Central Forums
  7. #7
    What about WiFi Direct? I haven't tried it, but the phone supports it: Settings -> More settings then enable Wi-Fi Direct
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
  8. #8
    I only have this problem on non Windows 7 computers. I tried installing the drivers on the other one, but it just wouldn't take. (but yeah, first pull down the drop down on your phone for and switch from camera to media) That wifi file explorer is probably your best bet though. Or an actual card reader and popping out the SD card if you store everything there.
    geekymcfly likes this.
  9. #9
    Quote Originally Posted by daniboy1_2_3 View Post
    Quote Originally Posted by iCrank View Post
    Update the drivers
    Quote Originally Posted by drmaf894c View Post
    Hope that helps.
    Quote Originally Posted by Ceetar View Post
    I have two different computers - one running XP, the other running Windows 7. Neither will recognize the device AT ALL, as ANYTHING. I get the error message popup from both computers, "USB Device Not Recognized." I've downloaded and installed the device drivers from Samsung on both computers, downloaded and installed the latest Kies app (with drivers) on both computers. I get no notification on the pulldown screen at all - nothing about a camera or a media device. Just the error popup on the computer. I'm about to tear my hair out! Any other suggestions here? Stock, unrooted AT&T S3.
    Longtime BlackBerry user, navigating my way through the Android forest,
    sometimes wishing for a better map!
  10. #10
    Did you try it with developer options both clicked on and clicked off? That might work.
    Edit: I meant USB debugging in developer options
  11. #11
    Quote Originally Posted by Something Creative View Post
    Hadn't - but just did, turned on USB debugging (it had been off-unchecked) and plugged it in again - same thing, no notifications at all on the phone, error message popup on the PC.
  12. #12
    Ricky Babalu's Avatar
    BEACH BUM
    Posts
    ROM
    Stock : Rooted, Unlocked
    Quote Originally Posted by DallasFlier View Post
    Have you checked to see if in the "Device Manager" on your PC there aren't any issues with the drivers? Have you ruled out a bad cable? Also, try a different USB port (one in the back, not the front).
  13. #13
    Quote Originally Posted by Ricky Babalu View Post
    Been away a few days... Device manager shows no problems with any devices, all operating properly, in particular the USB ports. Have tried different cables, different USB ports, even different computers! Laptop on Win7, desktop on XP. Exactly the same results no matter what. Additionally, same ports on same computers using same cables all recognize and work just great with my wife's BlackBerry.
  1. Phone won't sync as a media device
    By guinnkevinr in forum Samsung Galaxy S3
    Last Post: 06-16-2013, 03:15 AM
  2. S3 not being recognised as media device by computer
    By Alex Risdon in forum Samsung Galaxy S3
    Last Post: 12-26-2012, 12:55 AM
  3. Replies: 4
    Last Post: 10-28-2012, 02:55 PM
  4. My phone syncs properly as a media device
    By Soundtrack to Chaos in forum Samsung Galaxy S3
    Last Post: 08-04-2012, 06:20 PM
  5. NC Froyo not listed as device in online Market
    By azjerry in forum Barnes & Noble Nook Color
    Last Post: 03-24-2011, 10:25 PM
