1. kimbolas's Avatar
    Hi everyone,
    Just got a Samsung GS3 and for some reason many apps seem to be running all at once, although I haven't even opened most of them them!
    I have been advised to go to my apps manager and shut them down, however, once this is done and after I haven't been using my phone for a while, as I open it many running apps just pop up!!
    Also, once I'm done with an app I usually just press the return key to take me to the idle side of the phone, is this better or should I simply just press the home key?
    Any ideas will be much appreciated, as I'm kinda useless when it comes to these probs.
    Cheers
    11-03-2012 07:23 PM
  2. smooth4lyfe's Avatar
    You could use "Advanced Take Manager" to automatically kill apps that are running, its pretty useful
    https://play.google.com/store/apps/d...NrbWFuYWdlciJd
    11-03-2012 11:59 PM
  3. drmaf894c's Avatar
    Also make sure to clear your ram on a regular basis as well as holding down the home key will bring up recent apps. Make sure to close them there. That will help to keep them closed too. Also you can disable any apps that you don't need. May help.
    Sent from my Samsung Galaxy S III using Android Central Forums
    11-04-2012 12:10 AM
  4. Srambo217's Avatar
    Do NOT use task killers. They kill background processes necessary to maintain a proper signal and system operations.
    Look for a detailed battery manager app, if these apps aren't hurting your battery life significantly than don't worry about them.
    Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
    geekymcfly and funkylogik like this.
    11-04-2012 01:58 AM
  5. smooth4lyfe's Avatar
    Actually for this one, you choose what you want it to kill...it doesn't kill everything on your phone like others so this one is safe...I use it and it automatically closes apps that you want to close that you never know are running in the background..this one is safe
    11-04-2012 01:20 AM
  6. Tarant's Avatar
    Being able to kill a single is nice if you have an app causing problems. However you smartphone is smart enough to shut apps down when the system needs more ram. Just let the device do what it was designed to do.
    funkylogik likes this.
    11-04-2012 01:27 AM
  7. pinatiger's Avatar
    If I were you just freeze all apps you do not need. And yes clear your ram often.
    Sent from my SGH-T989 using Tapatalk 2
    11-04-2012 01:54 AM
  8. funkylogik's Avatar
    the way i see it, just forget about it. most of those apps are doin nothing. let the phone deal with it
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    11-04-2012 06:30 AM
  9. jamesino's Avatar
    Why do you need to clear your RAM often? Apps do not consume battery life as long as they aren't using up the CPU %. By taking up RAM and using 0.0% CPU, the app is not taking up battery, despite taking up RAM. In a case where you run low on RAM, the OS will automatically kill processes to free up RAM.
    11-04-2012 06:36 AM
  10. funkylogik's Avatar
    ...yup its just remembering where you were in the app (cache) i think
    11-04-2012 07:34 AM
  1. Way too many force closes on EC05
    By Ram210 in forum Sprint Epic 4G
    Last Post: 04-08-2011, 08:09 PM
  2. How many apps is too many apps
    By saywut in forum HTC EVO 4G
    Last Post: 03-08-2011, 08:56 AM
  3. Replies: 0
    Last Post: 02-23-2011, 07:58 PM
  4. HTC Senses crashes with too many app shortcuts?
    By isosunrise in forum HTC EVO 4G
    Last Post: 07-02-2010, 12:50 AM
  5. Apps Running on Background on their own?
    By djlee0314 in forum HTC EVO 4G
    Last Post: 06-07-2010, 12:29 PM
