I'm on At&t and have the GS3 and thinking of going to the Nexus 4.... Anyone else thinking of doing the same?
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
The lack of a MicroSD card is a kill to me, so with that being said....no
I really considered it. I was torn between buying the new penny Hardaway, the note 2 and n4. Fortunately I could afford all of them but I decided to just go with the 32gb nexus 7. The sd card doesn't bother me as much as it does the others bc it would be a secondary device.
"all animals are created equal but some animals are more equal than others" animal bylaws- animal farm
Agreed completely, not worth it for me to upgrade my phone so soon. I'd rather put some miles on my S3 first, and then consider upgrading next year to whatever is available then.
Install juice defender, you'll thank me later.Battery life on the S3 will still probably trump the nexus4.
Yeah I'll he moving from the S3 to the Nexus 4.
There we're quite a few things I was disappointed about the S3 and stock Android can't be beat.
And if anyone says to flash an AOSP/AOKP rom, I'd want to slap them.
Sent from my GT-I9300 using Tapatalk 2
I have juice defender installed works like a charm now if I could only get it to do g he same for my girl's Lg esteem... her battery literally lasts ~4hrs or so with moderate use. We leave the house, someone sends her a video poor girl won't even open it
Sent from my SCH-R530M using Android Central Forums
How much do you like her? Time for a new phone.....
Sent from my SCH-I535 using Tapatalk 2
I had it on my other juice draining phones and it helped a lot. I havent used it on the SGS3
If I remember right, it also cycles down the CPU to the lowest which saves juice. It does a few other things as well
