Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Paul627g
  • 1 Post By Skunkape60
  • 1 Post By Srambo217
  • 1 Post By funkylogik
    birdy141's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help
    Could you please give a little more info as to what you were doing with Kies when this happened? Along with which version of OS, etc. you were on so we can properly formulate a solution.
    Thanks.
    funkylogik likes this.
    birdy141's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help
    anyone know what this means?
    birdy141's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help
    on windows 7. just trying to connect s3.. this comes up twice and kies never finds phone.
  5. #5
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Default Re: help
    im a pc 'tard but id suggest reinstalling kies and rebooting pc?
    good luck man
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
  6. #6
    Skunkape60's Avatar
    Retired Ambassador
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help
    I have had all sorts of problems with windows 7 and the gs3 connecting when using Kies. So much so that I've quit trying to use it and just install the drivers only. Another trick I've learned on the AT&T forum is to block windows from updating the drivers. My phone and computer would connect for a day or so and then would stop. I would have to remove and reinstall the drivers to get it to work again. Then a couple days later it would stop working again.
    To keep windows from updating the drivers:
    -Right click on my computer and choose properties.
    -advanced system settings from left side of window.
    -from the hardware tab click "device installation settings"
    -select "no,... Never install driver software from windows update.
    Remove kies and samsung drivers.
    Then install drivers from here.
  7. #7
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Default Re: help
    take it you have to reverse that if you need to install some kind of driver for something else bro?
  8. #8
    Srambo217's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help
    Quote Originally Posted by birdy141 View Post
    I assume a prediction of when the Rapture will take place.
    Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
  9. #9
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Default Re: help
    Quote Originally Posted by jaj6503 View Post
    theres that humour ive grown to appreciate :beer:
    birdy141 likes this.
  10. #10
    Skunkape60's Avatar
    Retired Ambassador
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help
    Quote Originally Posted by funkylogik View Post
    No, Windows will now offer the driver updates. You will be able to choose which ones you want. I would suggest not updating the usb or samsung drivers unless you are having issues. And if it messes it up, at least you will know what update to uninstall.
  1. HELP! Need to get G1 Working or Dieter Will Kill Me!
    By Rene Ritchie in forum The Android Central Lounge
    Last Post: 06-02-2013, 04:17 PM
  2. My Turn - Help Dieter with the G1
    By Dieter Bohn in forum The Android Central Lounge
    Last Post: 04-26-2013, 08:08 AM
  3. Round Robin: Help Jennifer with the G1!
    By Jennifer Chappell#CB in forum The Android Central Lounge
    Last Post: 12-14-2009, 09:59 PM
  4. SOS: All G1, Gmail, Gtalk contacts disappeared. Please help!
    By android007 in forum General Help and How To
    Last Post: 03-17-2009, 05:28 PM
  5. SOS: Please Help: IMport SMS from XML file to G1
    Last Post: 02-06-2009, 12:15 PM
