Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By johnnyshinta
  • 2 Post By GSDer
    johnnyshinta's Avatar
    Posts
    Global Posts
    3,192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery icon
    Is it just me or does the battery icon in the notification bar not change at all. I checked the actual level a little bit ago and it was 84% checked again and it's 77% and the icon hasn't changed at all.
  2. #2
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Default Re: Battery icon
    yeah its pretty crap mate, maybe only does 10% incriments. wish it could be disabled. i use a nice big coloured % indicator anyway..
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
    Posts
    Global Posts
    3,192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What apo do you use?
  4. #4
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Battery Notifier (big text)Click image for larger version.
    thats it top left, it changes colour as percentage drops and shows temp and voltage in the notification area (the white number next to it is just an app showing cpu percentage)
    Posts
    Global Posts
    3,192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by funkylogik View Post
    I think you're right. It looks like it does update on 10% increments.
    funkylogik likes this.
  6. #6
    kevin5377's Avatar
    Posts
    Global Posts
    162 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can turn on percentage display without an app
    Sent from my Asus Transformer Prime on Android Central Forums
  7. #7
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ^ Too bad he didn't provide specifics. If you go to Settings -> Display and look under the More settings section, just check Display battery percentage
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    unlmtdRW and funkylogik like this.
  8. #8
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Quote Originally Posted by GSDer View Post
    mine actualy displayed by default but i turned it off, BN is far nicer
    Posts
    Global Posts
    3,192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks. I know how to turn it on. I was trying to survive with it turned off because I find that if I have it turned on I worry about the battery level more. I can see it counting down and notice when it drops a certain level in a certain amount of time. But the battery icon is just way to ambiguous. I considered using the gsam battery monitor pro but I feel like I obsess even more when I have that installed. I check it all the time to see how much time I have left on the charge and what is eating the battery. I guess I'll stick with the default percentage for now.
  10. #10
    kevin5377's Avatar
    Posts
    Global Posts
    162 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry, I usually do, but I wasn't in a place to do that. No need to be trollish about it.
    Sent from my Galaxy S3 on Android Central Forums
  11. Thread Author  Thread Author    #11
    Posts
    Global Posts
    3,192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Does anyone prefer the battery icon over the %
  12. #12
    Almeuit's Avatar
    Posts
    Global Posts
    23,210 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by johnnyshinta View Post
    I like the percent.
    Sent from my Sprint S3 using AC forums
  13. #13
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    I use a custom percentage app.. would love to disable the ugly battery icon
    Unbranded Official TW s3.Paisley,Slotland, Western Europe :beer:
  1. Battery Percentage instead of battery icon?
    By elder_shawn in forum HTC EVO 4G
    Last Post: 12-23-2011, 04:20 AM
  2. Circular Battery Icon?
    By adleyh2000 in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 09-12-2010, 02:26 PM
  3. ? over my battery icon?
    By lysiesmommy in forum Motorola Droid
    Last Post: 07-21-2010, 10:10 PM
  4. Looking for new battery icons.
    By droid 8172 in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 05-11-2010, 11:26 PM
  5. color of battery icon
    Last Post: 03-07-2010, 12:01 AM
