DEAL OF THE DAY: Save 28% on the Seidio OBEX Waterproof Combo for Samsung Galaxy S3!
Results 1 to 11 of 11
    Dog5000's Avatar
    Posts
    Global Posts
    294 Global Posts
    Default Kies Air - Denied and No Devices Found
    So, I just updated to the latest Kies Air version the other day and tonight thought I'd use it to grab a few photos and copy to my MacBook Pro.
    After starting Kies Air and receiving the IP address to use for my MacBook browser (could be another phone, tablet, or computer for that matter), I started typing in the IP address into a new browser tab not more than five seconds after the IP address popped up from Kies, and then received a new pop-up that masked over the prior IP address details. This new popup only gave the choice to Deny. So I clicked Denied, and now get the option to Scan for Kies Air Server, and upon choosing the Refresh Kies Air just spins in a loop "scanning" and eventually returns "No devices found". I finally clicked Cancel out of the Refresh function, and then get directed to a new popup window called Deny access. This in turn tells me that I have to restart Kies Air in order for my laptop to access the Kies Air web services.
    For an application that was working before this version (2.2.211011, Nov 2nd), what a step backwards. I've used it enough to know what to do, and have some understanding about how client/server web applications work, so I don't believe its "user error".
    Anybody else experiencing this? Is this a one time problem after upgrading? In theory this problem shouldn't be isolated to any particular OS or browser version; or just for the S3.
  2. Thread Author  Thread Author    #2
    Dog5000's Avatar
    Posts
    Global Posts
    294 Global Posts
    Default Re: Kies Air - Denied and No Devices Found
    I should have known better and read the Google Play reviews before updating. Uninstalled updates and disabled the app. Many others are having similar if not the exact same issues. At least I got a few good laughs out of the Play reviews. Some serious four letter words being lobbed Samsung's way on this one. Time to check out AirDroid again.
  3. #3
    Quote Originally Posted by Dog5000 View Post
    I havent had any problems with this. I was able to text from my laptop while my phone was in my pocket and it worked fine for me.
    But i seem i am in a small minority with this
    Dog5000's Avatar
    Posts
    Global Posts
    294 Global Posts
    Glad its working for you. I may come back to it later on if the current bugs and improvements are made. Just seems odd that the manufacturer can't get their own software thats designed to manage their own hardware right.
  5. #5
    Yes you are right. If you release anything it should be working 110%!!!! Though I must admit I don't really use it much it it is handy to have
    Sent from my GT-I9300 using Android Central Forums
  6. #6
    U should go back to air droid. It works great for me
    HTC Evo 3D rooted & running custom Nocturnal Venom Rom. My phone sleeps in the bed and my girl is on the couch
    Dog5000's Avatar
    Posts
    Global Posts
    294 Global Posts
    Quote Originally Posted by makaroni View Post
    Yes, AirDroid is what I'm using now. I'm not moving stuff to/from my phone that frequently, so its not a huge deal. But when you need to, then it should not be an ordeal. I'm experimenting around with other WiFi based apps, and still have Kies working if I need to go the USB connected route.
  8. #8
    I agree that it shouldn't be a huge ordeal. I have minimal patience myself. Sounds like u got a few options so good luck with it. If u find any good ones let us know.
  9. #9
    Finally figured this out bought this phone today for my wife, figured I shared with all you are having this issue. Please do the following in this order:
    Prep:
    1. Check under Settings -> About phone if there are any software updates necessary on the phone. If you are up to date great! please move to the next step.
    2. Install and download Kies software from website (), once installed make sure to enable all the necessary setting in windows and or Mac to allow to the phone to be discovered on the network (must be on the same network)
    3. Executed Kies Air Messenger located under tools and follow
    4. Once Air Messenger has been configured (follow prompts) and connected you should then proceed to the following steps to be able to connect to Samsung Kies Normal or Lite Mode (aka Server) the following needs to be done through the phone.
    Connection to Server Steps:
    1. Go to Settings (make sure the KIES software is open during this process)
    2. Under Wireless and Networks select more settings
    3. Scroll all the way down (should be the last item) to where it says KIES via Wifi and select it
    4. It should automatically already find your PC based on the Air Messenger Service that is running.
    If you have any other issues and or need further assistance please feel free to email me directly at
    The last step (connection to server steps) can also be found by clicking Help-> Kies Tutorial on the 2nd page under the heading "Connect a mobile phone via Wifi" It's a video.
    Thanks,
    Javier
  10. #10
    I gave up on Kies. Try ES file explorer.
    --Tapatalk 2 on SGS3.
    Samsung Galaxy S3 4gLTE
  11. #11
    darkfusion this works perfectly thank you sir
  1. Trying Kies via Wi-Fi - Scan for Kies air server - No Devices
    By chrischarles2002 in forum Samsung Galaxy S3
    Last Post: 04-06-2013, 10:30 PM
  2. Root NS4G w/ICS and no device wipe?
    By giograves in forum Sprint Nexus S 4G Rooting, ROMs, and Hacks
    Last Post: 04-27-2012, 10:53 PM
  3. Replies: 9
    Last Post: 03-07-2011, 11:36 AM
  4. "No Driver Found" Windows 7 (64 and 32 bit)
    By jordo_99 in forum Verizon Fascinate
    Last Post: 09-20-2010, 11:09 AM
  5. Lost and no found Widgets
    By DBLX in forum Motorola Droid X
    Last Post: 09-06-2010, 08:47 PM
