Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By smooth4lyfe
    Perseveranze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default My phone won't connect to wifi... [IMPORTANT]
    Hey,
    I got a really bad problem. My Samsung GS3 won't connect to my Uni's wifi. It connects to every other wifi, except my Uni's. This is a problem because I'm on low Mobile Data allowance, and that's because I didn't know my phone wouldn't be able to connect to my Uni's wifi...
    And it's something wrong with mine (which is specifically a 4g/lte), since my friend has a Samsung GS3, and that connects fine.
    Anyways, I think it has something to do with the 802.1x EAP wifi's... when I try to connect, it just keeps saying connecting and sometimes ends up "Authorization error".
    Here's some screenshots;
    Would appreciate any possible solutions to try.
    Thanks.
  2. #2
    bblaze's Avatar
    Android Powered Human
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock ROM / Rooted Kernel
    Default Re: My phone won't connect to wifi... [IMPORTANT]
    Is the identity that you are putting in correct? Some places require that it is preceded by a domain name, if applicable. For example it would be domain\username (i.e. abc\user123) Verify that all settings are correct before connecting. Not much else could be wrong with it beside input/settings errors.
  3. #3
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    can you try telling it to "forget" the wifi network and then set it up from scratch?
    global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess
  4. #4
    smooth4lyfe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I was at school, I would have to log in with my School ID and password on the computer first to activate the network before I could use the internet...check your schools internet policies to see if there is something extra you need to do
    funkylogik and unlmtdRW like this.
  1. Phone won't connect to PC or MAC
    By bailcam in forum Verizon Droid Incredible
    Last Post: 10-20-2013, 12:30 PM
  2. phones won't connect to wi-fi
    By NicoleW78 in forum General Help and How To
    Last Post: 09-08-2013, 12:34 AM
  3. My pc won't connect to phone after downloading drivers
    By Joemarsico in forum Verizon Galaxy Nexus
    Last Post: 05-11-2012, 03:29 PM
  4. Phone won't connect to wifi or 3g network
    By palmer0700 in forum Samsung Replenish
    Last Post: 04-25-2012, 01:39 PM
  5. My MAC won't connect to EVO WiFi
    By Jenayalynn in forum HTC EVO 4G
    Last Post: 09-03-2010, 01:38 AM
