Results 1 to 8 of 8
- 11-08-2012, 09:35 AM
Thread Author #1
Problems with Galaxy S3 using an Ibolt car dock and Car Home Untra
I am having to different problems I am hoping someone can help with. I have a Galaxy S3 using an Ibolt car dock with Car Home Untra and am having the following problems.
1. The phone call audio will not play through the speakers. I do have an aux jack that has worked with other car docks in the past. Music will play through the car speakers fine.
2. When I leave the phone in the charger during the day, obviously with the car off, the battery drains to 0%. In other words, either car home ultra or the ibolt charger is discharging my battery.
Any help will be much appreciated. - 11-08-2012, 10:33 AM #2
Re: Problems with Galaxy S3 using an Ibolt car dock and Car Home Untra
I am pretty sure I have the same problem with phone calls not playing through the speaker with the Infuse4G dock and Car Home Ultra. I honestly haven't used it though for awhile since I always have on my bluetooth headset in the car so rarely use the speaker phone. I can try it out later I suppose.
No suggestion on the battery drain issue since I wouldn't leave my phone in the car all day. But it's easy enough to determine if it's Car Home Ultra by pressing Menu->Exit to close Car Home Ultra. If it still drains, then it must be the dock. - 11-08-2012, 01:10 PM #3
- 11-08-2012, 01:19 PM #4
- 11-08-2012, 01:39 PM #5
1. iBolt does not route phone calls through your car speakers. This is a Samsung thing, not an iBolt problem.
2. I'm guessing icnmayhem is right on the money as to your power problems. Easy enough to check by putting your phone in the dock with your key off then watching the charge indicator as you turn your key on or start your car.Blessed are they who can laugh at themselves, for they shall never cease to be amused.
AOKP 4.2.2 Milestone 1 - 11-08-2012, 02:16 PM #6
I will also verify that the in-call audio does NOT go through the dock, no matter which dock you use. This is a Samsung limitation that bugs me. You can, however, use a bluetooth headset or speaker to pair with and route calls through that. You can pair it so that it only receives the in-call audio and the A2DP audio still goes out through the dock to your vehicle speakers.
Speaking to the battery drain, keep in mind that CarDockUltra does ping location services, so it is probably using a good amount of juice. Like others have pointed out, if your vehicle doesnt provide power to that outlet, you are not charging your device. You can tell when the iBolt dock is on as it will have a blue light. If you dont see this when your vehicle is off, then you are not receiving power.Treo 300 -> Treo 600 -> Treo 650 -> Treo 700p -> Palm Pre -> Samsung Galaxy S II Sprint Epic 4G Touch->Samsung GS3 16GB Pebble Blue - 11-08-2012, 03:58 PM #7
As for the charging issue, I assumed he had left the phone screen off and everything, but just in the dock. If so, then you're probably right on Car Home Ultra draining it (as djjr50 points out, it's going to keep pinging for location constantly, because it uses that for the speedometer and direction/compass calculations).
If you're going to leave your car in the dock for some reason while you're not in the car and it's not running, exit Car Home Ultra and then it will probably be fine and won't drain your battery. - 11-15-2012, 01:57 PM #8
problem with internet access using wi-fi
By hamsteak62 in forum Samsung Galaxy S II SkyrocketReplies: 18Last Post: 12-03-2012, 08:41 PM -
galaxy s3 the case on the phone and any ear buds i use with mic and buttons
By guzzardo in forum Verizon Galaxy S3Replies: 2Last Post: 09-13-2012, 11:19 PM -
Problem with Galaxy S3 and Bluetooth Speakerphone
By cosrocket in forum Verizon Galaxy S3Replies: 4Last Post: 07-14-2012, 07:55 PM -
Foxfi password problem with Galexy S3
By rejdmast in forum Verizon Galaxy S3Replies: 3Last Post: 07-14-2012, 05:52 PM -
Car dock and Car Charger Recommendations
By brichter45 in forum EVO AccessoriesReplies: 21Last Post: 07-13-2010, 01:06 AM
Reply
