- 11-16-2012, 12:09 PM
Thread Author #1
Serious issues after upgrading firmware
Help me Android Central; you're my only hope!
Pre-amble - I recently decided it was about time I handed in my iPhone 3GS after 3 satisfactory years. Unimpressed by the iPhone 5 I opted for the S3 a little over a month ago and generally I have been impressed. However that has altered somewhat since I recently upgraded the firmware to PDA:LJ4 / PHONE:LID / CSC:LJ4 (BTU). Doing this generally cocked the phone up - it kept locking and giving messages about "android.process" not functioning. After some searching on this issue I decided my best bet was a factory restore and then simply load the phone again. This I did and now...
For whatever reason both 'Driving Mode' and 'External Speaker Mode' do not function.
For external speakers I have checked "Settings>Accessory>Audio Output Mode"
For Driving Mode I have switched on "Language and input>Text-to-speech>Driving Mode"
Tell me there is soulution - don't make me wich I was back in the simple world of Apple!
Cheers,
James - 11-17-2012, 11:27 AM
Thread Author #2
- 11-17-2012, 11:42 AM #3
Re: Serious issues after upgrading firmware
Hi James — I came from being a longtime 3GS user as well, but I have no idea how to help you. I read your OP last night, and expected some member(s) to soon come to your aid, as they typically do around this forum; sorry no has as yet.
Here's an idea . . .you can go to both your carrier's & Samsungs websites and download the [ .pdf ] for your exact phone model, as well as read through each sites tutorials for your phone. Maybe there's instructions for rolling back a firmware flash? I don't know though. Best of luck to you.
- 11-17-2012, 01:22 PM #4
Hello - I am not familiar with the update version you have noted, what carrier are you with? Is it international?
Sometimes downloads have hiccups and need to be redone, I would first suggest you try a simple battery pull to see if that helps. If it does not then Factory Reset again, but make sure you have a good signal when doing so and a fully charged phone. - 11-17-2012, 03:18 PM #5
Yes, you probably should have stayed with an iPhone.
The first difficulty in being able to help you is a result of different features for different carriers - my Verizon SGSIII doesn't even have an 'Accessory' menu, so I won't be able to make any suggestions there.
Regarding 'Driving Mode' - what is (or isn't) happening when you try to use that feature? I haven't used it myself so a little explanation of how it used to work vs. what is going on now would be useful.
It's not possible to roll back to a previous version of firmware unless you root your phone - it would probably be better to see if we can solve these problems rather than introducing the overhead of dealing with a rooted phone.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2 - 11-17-2012, 03:27 PM #6
Id have suggested factory reset but i see youve done it. I read about a samsung approved way of factory restoring after an upgrade to get rid of the gremlins.
You could ask Sir Mervin King (dude on these forums)
As he knows how.
Good luck mate :thumbup:
Unbranded Official TW s3.Paisley,Slotland, Western Europe :beer:GT-I9300, UK
Thanked by: - 11-17-2012, 04:01 PM #7
- 11-17-2012, 05:16 PM #8
Very helpful!
- 11-17-2012, 06:56 PM #9
I would have suggested going via Kies for the update rather than an OTA update, but with that said, I honestly don't have a solution for you(I am still fairly new to the S3 myself). You could try rooting your phone and then going to a cyanogenmod Jelly Bean if all else fails.
Thanked by: - 11-17-2012, 08:06 PM #10
Is there a way to re-install firmware like u would with an app?
- 11-18-2012, 05:55 AM
Thread Author #11
I'm with O2 in the UK
Driving Mode used to automatically be engaged when I plugged the phone into my dock in the car. The phone would say "Driving Mode Enagaged" or something similar and then S Voice would open. Now nothing happens.
Likewise the dock would allow me to play music through the car stereo and Navigation app alos worked through the stereo, which used to work just fine and and now they don't, it just plays through the built in speaker. I tried playing my phone through my amp ay home as well, but tyhat also just plays through the in built speaker. - 11-18-2012, 05:58 AM
Thread Author #12
- 11-18-2012, 01:28 PM #13
This has been reported elsewhere as a new problem with the JB update -- removes these features.
Bothers me a LOT because I'm using the iBolt Car Dock through Bluetooth, and according to other threads, once I update to JB (through Verizon), I won't be able to use that anymore.
Sorry, no solution ... but Samsung has admitted this to be a problem and is (supposedly) working on a fix. No telling how long (weeks? months?) it will take to get that fix done and out to folks.Thanked by: - 11-18-2012, 01:39 PM #14
First off, to all of you saying go back to the iPhone, that is not what we are here for and it is rather unproductive not to mention rude and stupid. Our community is here to help people.
Next, to the OP. you can roll back the update with a bit of work. Not too much and nothing all that complicated. The trick will be to not accept the update in the future.
Once I get access to a computer, in a hour or so, I will try and dig up the stuff you need.
Can you do me a favor and go to settings-->about phone and give me your model number and baseband version? I am in the us and I want to be sure to get you the right stuff for your phone as to not it up anymore
Sent from my X-Band Modem... TY GenesisThanked by 2: - 11-19-2012, 12:19 PM
Thread Author #15
- 11-19-2012, 09:55 PM #16Thanked by:
- 11-20-2012, 03:38 PM
Thread Author #17
- 12-09-2012, 03:25 PM
Thread Author #18
- 12-09-2012, 03:27 PM
Thread Author #19
Bluetooth issues after upgrade to ICS
By gzbsds in forum Samsung Galaxy S II SkyrocketReplies: 7Last Post: 02-15-2013, 01:37 PM -
WiFi issues after upgrading to ICS - Solved
By maxud in forum AT&T Galaxy S IIReplies: 9Last Post: 02-03-2013, 05:02 AM -
Kies air issue after upgrade
By KD8MLY in forum Sprint Galaxy S II Epic 4G TouchReplies: 1Last Post: 04-29-2012, 10:47 PM -
Text Message Issues after upgrading to 2.3
By Dre3001 in forum HTC EVO Shift 4GReplies: 3Last Post: 08-13-2011, 12:38 PM -
for those with batt issues after upgrade
By flynlow in forum Sprint Epic 4GReplies: 73Last Post: 09-28-2010, 06:48 PM
Reply
