I just got this phone for cheap off kijiji so I am not surprised there is something wrong with it. But this is kinda a big issue to me. I charge the phone all night and have 100% when I unplug it. about 20-30 min after its unplugged the phone is at 50% and then stays there, It will then go down at a normal pace then drop off to nothing and stay there for about an hour.
Is this a problem with the phone? Do I need to get some update or hack to fix this? OR is it the battery and I need a new one?
What I have done so far is factory reset using the settings menu and also the recovery mode when turning on the phone.
Its not any apps or heavy use that is the cause. I have not "extra" apps installed other than facebook and im not even using it. I am not a heavy phone user and the WiFi and Bluetooth is off. Also Power Save mode is on.
I took some screen caps of the battery history screen so you can see what I mean.
Thanks guys and gals in advance for the responses.
