Results 1 to 6 of 6
    tuffy100's Avatar
    Posts
    Global Posts
    1,088 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Persistant LED (Won't Turn Off)
    Hey all,
    So I've noticed that whenever I turn my screen off, there is a red LED notification light that stays on. It goes away when I reboot, but shortly after I boot back up it'll just come back on.
    I don't have any notifications or anything like that, which is the weird part. I do have Light Flow installed, but I did a thorough search through the settings and all that and it's not anything in there that's causing this.
    Any ideas?
  2. #2
    soli2005's Avatar
    Posts
    Global Posts
    43 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Persistant LED (Won't Turn Off)
    I had a similar problem when I installed liteflow except it was a blue led that kept on. I checked all the settings and everything seemed right and i uninstalled the app and it solved my problem. I can live without liteflow but I'm guessing the app is to blame.
    tuffy100 likes this.
    tuffy100's Avatar
    Posts
    Global Posts
    1,088 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by soli2005 View Post
    I'll try deleting it....................
    Yup, that did the trick. Shame, I just had Light Flow all set up! Ah well.
    Thanks!
  4. #4
    trucky's Avatar
    Posts
    Global Posts
    6,367 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    LF did the same thing to me. Booted that suckah.
  5. #5
    Srambo217's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lightflow is to blame. It's been well documented across the interwebs that Lightflow and the GS3 don't get along.
    Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
  6. #6
    cgardnervt's Avatar
    Posts
    Global Posts
    2,048 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None Yet...
    If you still have Lightflow and you wanna use it try turning the device off then pulling the battery for about 30 seconds. That did fix it for a friend of mine. Let us know how it goes for you.
  1. My screen won't turn off any ideas?
    By wormeyman in forum Motorola Droid X
    Last Post: 09-07-2016, 03:07 AM
  2. Screen won't turn off
    By longbow in forum HTC EVO 4G
    Last Post: 09-02-2013, 10:55 AM
  3. LED Notification WONT Turn off...
    By Nebilim in forum HTC EVO 4G
    Last Post: 07-14-2011, 02:18 PM
  4. Power Button Won't Turn Off Display
    By JojoSteez in forum Sprint Epic 4G
    Last Post: 11-19-2010, 11:59 AM
  5. Screen won't turn off when charging
    By gatortuba in forum Verizon Droid Incredible
    Last Post: 08-02-2010, 04:49 PM
