Why does brightness get very dim only when using browser?
My wife's SGS3 has recently started doing something odd. When she launches the internet app (the stock one called "Internet" with the blue globe icon) the pages display VERY dim, like less than 10%. Switch to any other application and display is normal, switch back to browser and it is dim. Checked the settings and they are Brightness=100% and Automatic Brightness is unchecked. She does not have any auxillary brightness controllers (like Lux) and it is just the browser app. Even the Google Navigator works fine. Any ideas?
Verison USA service. Standard Setup, not unlocked or ROM'ed.
Re: Why does brightness get very dim only when using browser?
When you said you checked the settings, did you mean the internet settings or the main phone settings? The internet app has a brightness slider of its own
i had the same problem. i deleted stock browser and went to dolphin. i now have a very bright screen. display is uncgecked auto and put brightness all the way
Sent from my AT100 using Android Central Forums
Yes, I meant the phone brightness setting. I looked for a brightness setting on the app and didn't find it, where is it??
I thought something was wrong also. There is a brightness setting within the browser to dim the backlight to save battery life while browsing. You can manually turn the brightness up in the settings for the browser if you want, so try that and you should be good. I would agree with the previous post and download Dolphin browser. It's way better and had some more features. Stock Internet app is blah. Good luck
Sent from my SCH-I535 using Android Central Forums
just open the browser to any page, hit the menu button and one of your options there will be brightness. If for some reason it isnt there, go into setting and it should be there.
I can't believe it. It was right there, I just didn't scroll down the menu list!! Fixed, thank you
I tried adjusting the brightness inside the browser and it still wasn't as bright as the other apps. I found the solution however. Go into settings>power saving mode and uncheck "background color." This was also dimming my native email app, but it works fine now!
I love you man. I've been trying to find the fix for the "blueish tint" almost a year ago. It's funny how the blue tint might save battery.
This problem is very easy to fix. First make sure you do not have the power save mode on or it will not work. Then open your browser and press the menu key and there you will fin your brightness setting. No need to download an app.
