Results 1 to 4 of 4
    Default Music Player recommendation
    Please help. I have tried several and even paid for power play but I'm missing some features I really need
    First, I copied my iTunes folder to an sd card which is in the phone.
    My requirements are in order
    1) can control via blue tooth stop play forward backward
    2) when I select an artist or genre it will play the entire selection not just one album (power play does this)
    3) a biggie a back feature. Say I'm playing songs from an album. I switched to other apps have the phone in my pocket whatever. I need to hit the app widget again, at that point I can't go back from the song to the album to the genre. This is a real pain since I listen to say an artist I can't back up to the artist to pick another album or song.
    4) search. Ability to search for a song, album, or whatever
    5) this is a wish either self generated smart play lists or the ability to play songs like the one I am playing
    Anything that does all this?
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
  2. #2
    Default Re: Music Player recommendation
    I don't know about controls via Bluetooth but I think you will enjoy poweramp
  3. #3
    Deadly_Poison630's Avatar
    Posts
    Global Posts
    244 Global Posts
    ROM
    Stock Rooted
    Quote Originally Posted by 20blks View Post
    +1 I agree. If you don't like poweramp though then give player pro a try as well.
    Did I help you at all? Return the favor by giving me a "thanks"
    LG Rumor -> LG Rumor Touch -> LG Optimus S (Cyanogenmod 7.2 on 2.3.5) -> Samsung Galaxy S3 (M.O.A.R. on 4.1.2)
    Ok my bad I have power amp and wrote the message because I was frustrated with it not doing items listed. I have since found that it does do everything other than smart play lists. Someone should tell the developer that the app is not intuitive!
    SEARCH should be at the top of any list and not part way down to the right and called filter.
    There should be a play button on any list rather than having to go up a level and press on the item until a play menu shows. It's not intuitive!
    Now if only I could get started play lists, like 70's music or songs like the one selected. I'm sure that info is easily available on the web.
  1. Music Player Bug
    By redman213 in forum HTC Droid Eris
    Last Post: 01-21-2010, 04:34 AM
  2. Replies: 3
    Last Post: 01-11-2010, 12:59 PM
  3. Music Player App
    By o2bnclemson in forum Android Applications
    Last Post: 12-19-2009, 04:05 PM
  4. Ogg problems on G1 music player
    By hephaestion in forum General Help and How To
    Last Post: 12-01-2009, 05:38 AM
  5. Couple Droid Questions- Keyboard and Music Player
    By Scott4551 in forum Motorola Droid
    Last Post: 11-16-2009, 08:03 PM
