1. mdwright1032's Avatar
    I want a new battery but not one of those huge extended batteries because currently they don't make any good cases for those.
    Anyone know of a higher capacity battery that's the same size as the standard one? I have a good case that fits my g3 and don't want to have to put on a crappy tpu case for an extended battery
    12-03-2012 10:30 AM
  2. meyerweb#CB's Avatar
    If you check fleabay, and some of the other vendors of Chinese made batteries, you'll find all sorts of "high capacity" batteries in the standard size. Unfortunately, you'll probably find they don't actually last as long as the "lower capacity" stock battery. The laws of physics are the laws of physics, and even unicorns can't cram more cells into a stock size casing than the OEM battery maker can.
    My approach? Buy a set of cheap batteries and charger off ebay, and just swap when you need to. I've seen 3 batteries and charger for about 10 bucks. I used these on my HTC Evo. They're not equal to the OEM battery, but considering the price difference they're fine. Of the 2 batteries I bought, one lasted about 15 months, the other more than 2 years. Both had about 75% of the capacity of the OEM battery. At about $3 each, that seemed reasonable to me.
    12-03-2012 08:46 PM
  3. ramurphyjr's Avatar
    I have had new life put into my Evo 4G by purchasing the Anker batteries and charger off of Ebay.
    12-05-2012 08:51 AM
  4. GrooveRite's Avatar
    From past experience....non-OEM batteries tend to suck!!....unless its one of those huge brick batteries of course.
    12-05-2012 03:51 PM
  1. what's the highest number of apps that can be installed on one ph
    By Touchpaddle in forum General Help and How To
    Last Post: 08-08-2012, 10:05 PM
  2. Replies: 0
    Last Post: 05-29-2011, 06:37 PM
  3. Display always the highest source of battery drain?
    By jrdatrackstar1223 in forum Sprint Epic 4G
    Last Post: 01-12-2011, 06:34 PM
  4. does any one have or know where i can get a froyo rom for the fascinate?
    By Donaldo794 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 12-09-2010, 11:36 AM
  5. Replies: 9
    Last Post: 07-06-2010, 05:37 PM
