Results 1 to 14 of 14
- 12-03-2012, 10:01 PM
Thread Author #1
I got a pro tip to help games like Dead Trigger and Shadowgun perform better on S3
I love these games but was having issues with them. Before this fix even on low settings the games were having framerate issues and had ghosting all over.. I found a fix for them thanks to another user I read. This fixes the issues and should help with other games.
Go to settings>developer options>turn on> check disable hardware overlays.
Both games now run like a dream. I am assuming other games may have this issue and this may resolve them as well.Thanked by 2: - 12-04-2012, 04:39 PM
Thread Author #2
- 12-04-2012, 07:46 PM #3
- 12-04-2012, 08:11 PM #4PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 12-04-2012, 08:35 PM
Thread Author #5
- 12-04-2012, 10:41 PM
Thread Author #6
Re: I got a pro tip to help games like Dead Trigger and Shadowgun perform better on S3
Go inside your settings. Look down for developer options. Check the tap to turn it on. Then scroll down and check the tab that says disable hardware overlays.
- 12-04-2012, 11:30 PM
Thread Author #7
Sent from my galaxy sexy3 - 12-05-2012, 03:22 AM #8
Any idea how it affects battery life bro?
Unbranded international s3 with Official JB. Paisley, Slotland, Western Europe :beer:GT-I9300, UK
- 12-05-2012, 11:30 AM
Thread Author #9
Does not make a big difference. You could always switch it off when done playing game
Sent from my galaxy sexy3 - 12-05-2012, 11:37 AM #10
And in what way does it affect normal phone performance bro.. in other words.... why isnt it always switched on?
Dead Trigger rocks btw...
- 12-05-2012, 01:37 PM
Thread Author #11
Does not effect performance. Don't know why it's not on by default
- 12-05-2012, 02:03 PM #12
- 12-05-2012, 02:25 PM #13
- 12-05-2012, 05:21 PM
Thread Author #14
To answer all the questions.
I was having a major ghosting effect on both dead trigger and shadow gun dead zone. I know this phone should be easily able to handle these games but the games lagged and ghosted hard on my s3.
I then read a suggestion I put in the OP and both games perform beautifully now even at max settings. I don't know why and has not seem to effected my phone.
I am assuming maybe the cpu was doing the bulk of the work and this setting allows the gpu to share the load. Thats my assumption.
It is not jailbroken or hacked. Running stock firmware.Last edited by mdwright1032; 12-05-2012 at 07:23 PM.
EVO Connection Issues and Battery Issues - Tips, Advice, Common Knowledge...Just tryin to help!
By Jarnld in forum HTC EVO 4G LTEReplies: 0Last Post: 11-07-2012, 02:57 AM -
Launcher Pro How-To Help
By new droid user in forum Verizon FascinateReplies: 6Last Post: 09-18-2010, 01:00 PM -
Launcher Pro...Questions! Please help!
By BringTheRain403 in forum Android ApplicationsReplies: 5Last Post: 06-01-2010, 04:46 PM -
Need a themer to help me out a bit
By Jerry Hildenbrand in forum HTC Hero Rooting, ROMs, and HacksReplies: 29Last Post: 03-20-2010, 05:32 PM -
Ipod got washed today, what to do....
By Andrew Ruffolo in forum iPhone/iOSReplies: 19Last Post: 02-14-2010, 04:32 PM
Reply
