Howdy Folks,
I may have ran into a show stopper on the Samsung Galaxy S3. I need to have a PIN on my phone or some locking mechanism that is secured, swipe doesn't cut it, as I have working documents and phone numbers that can't be easily accessed. I have a hands free bluetooth device that works great when the phone is unlocked. However, S Voice doesn't appear to work when the phone is locked. I have checked my call settings and the make outgoing calls when locked is checked. It works when swipe is engage, however, this is not an option for me.
Do I need to disable S Voice? If so how?
Are there some settings that I'm missing?
Does anyone have a solution?
I sure hope so, otherwise, I will have to return the phone.
TIA for your responses.
Thanks,
Greg
Thanks,
Greg
