Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By empeyg
    empeyg's Avatar
    Posts
    Global Posts
    21 Global Posts
    Default Bluetooth calls from PIN locked Screen
    Howdy Folks,
    I may have ran into a show stopper on the Samsung Galaxy S3. I need to have a PIN on my phone or some locking mechanism that is secured, swipe doesn't cut it, as I have working documents and phone numbers that can't be easily accessed. I have a hands free bluetooth device that works great when the phone is unlocked. However, S Voice doesn't appear to work when the phone is locked. I have checked my call settings and the make outgoing calls when locked is checked. It works when swipe is engage, however, this is not an option for me.
    Do I need to disable S Voice? If so how?
    Are there some settings that I'm missing?
    Does anyone have a solution?
    I sure hope so, otherwise, I will have to return the phone.
    TIA for your responses.
    Thanks,
    Greg
  2. #2
    Default Re: Bluetooth calls from PIN locked Screen
    I use a Jawbone Prime headset where if I hold down the talk button it activates S-Voice and then I'm able to voice dial from my pin protected lock screen without having to unlock first. You should be able to do the same by holding down the talk button...or one of the buttons on your headset.
    empeyg's Avatar
    Posts
    Global Posts
    21 Global Posts
    Something I missed saying in my original post:
    I have two Bluetooth units (a BlueAnt S3 and a Motorola T505 unit). These are hand free units that sit on the vehicle's sun visor. They are not headsets. Pressing the talk buttons on the Bluetooth units never engage's the S Voice when the phone is locked.
  4. #4
    jmelan's Avatar
    Posts
    Global Posts
    31 Global Posts
    I have a plantronics discovery 925 that fails to activate s voice as well with pattern lock activated (att gs3)
    - s voice activates as soon as I unlock the phone, which is obviously not safe to do while driving.
    I think we need a list of headsets that are confirmed to be working/not working with pattern or pin lock enabled.
    I just ordered the new samsung hm3300 from newegg - will report back when I get it.
    Working:
    Jawbone prime (gwappa)
    Not working:
    Plantronics discovery 925 (jmelan)
    BlueAnt S3 (empeyg)
    Motorola t505 (empeyg)
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  5. #5
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    I dont understand the rest but i know how to disable s-voice if u want mate?
    Unbranded international s3 with Official JB. Paisley, Slotland, Western Europe :beer:
    GT-I9300, UK
    empeyg's Avatar
    Posts
    Global Posts
    21 Global Posts
    I found a solution. I installed Tasker and Secure Settings. In Tasker, I create a profile for when my bluetooth device connects to my phone. I then created a task that disables my PIN.
    I also created a profile that re-enables my PIN when the bluetooth connection is lost.
    I still say that Samsung has this screwed up and I'm very disappointed that I even had to install third party software to make this work.
    Greg
    Thanked by:
    JodiElle70 likes this.
  7. #7
    Are you actually able to make calls with S Voice while using BT? I find that it cannot understand me over BT (headset) -- I must be close enough to the phone for the phone's speaker to recognize the voice.
  8. #8
    Quote Originally Posted by empeyg View Post
    Greg
    Might I suggest you go to the Samsung support site and tell THEM it's messed up? They're not likely to try to fix it if they aren't aware it's a problem, and I doubt they carefully read every post here.
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
    empeyg's Avatar
    Posts
    Global Posts
    21 Global Posts
    Sorry, I don't use a BT headset, so I can't assist you. Our hands free devices are for vehicles and sit on the visor.
  10. #10
    Cool Re: Bluetooth calls from PIN locked Screen
    I too had major issues with my S3 here in Canada on the Rogers Network. S Voice was too unreliable even with the phone completely unlocked. With a PIN, nothing seemed to work including Vlingo and several other 3rd party solutions. My solution/workaround was trying MotoSpeak. I have a Motorola T325 visor mount and a Motorolla HX550 headset. After installing MOTOSPEAK voice dialing and even voice texting works flawlessly with my phone safely secured with a PIN. My work requires that I be able to make phone calls while I drive and the addition of voice texting gives me one more option to use. Let me know if anyone else has had similiar experienes with this software.
    Timbyts
    Thanked by:
    GSDer
  11. #11
    Greg,
    I'm trying to get the thing you setup to work. Do you have a step by step list to do this.
    Thx
    K
  12. #12
    Hi Greg,
    Thanks for your post. This sounds like the solution I need as well. Would you be willing to share your steps to create this particular profile in Tasker?
    Thank you so much,
    Jodi
  13. #13
    I am a little late to this thread but I just found a Parrot Slim Bluetooth that works with my screen lock. When I
    activated it, it asked permission to learn my contacts. After it did this when I activate a voice call with it, it dials
    the number I want itself and the phone lets it through. I don't have to have data on either as I keep it off to keep
    my battery life. I cant access any other features with it such as S Voice or talk to text, but I didn't need that
    anyway. I am thinking that any higher end Bluetooth that learns your contacts may actually be able to do this
    as I don't think this Parrot unit is all that special. I see this unit listed on eBay for as little as $40. Hope this
    helps someone.
  1. Can't open the Camera from the Lock Screen
    By jeffreytz in forum HTC EVO 4G LTE
    Last Post: 06-05-2012, 11:27 PM
  2. Making a call when PIN-locked?
    By natehoy in forum Verizon HTC Thunderbolt
    Last Post: 01-30-2012, 06:40 PM
  3. Phone Icon is gone from my lock screen
    By Procyonarc in forum HTC EVO 3D
    Last Post: 07-30-2011, 09:02 PM
  4. Phone Icon is gone from my lock screen
    By cgardner in forum HTC EVO 3D
    Last Post: 07-15-2011, 03:29 PM
  5. Emergency Call button on lock screen - keypad or straight to 911?
    By fletch622 in forum Verizon Droid Incredible
    Last Post: 09-15-2010, 05:10 PM
