Results 1 to 2 of 2
    Default What is the best dashboard mount and aftermarket car stereo to perfectly integrate with the GS3?
    I have a 2003 Buick with the orig. radio.
    I want to buy a dock and after market stereo that will work perfectly for my GS3 for playing music, taking phone calls, nav, and everything else the GS3 does.
    Please be very specific about which models.
    Blue tooth? if so which ones work perfectly?
    One with a usb connector? or ???
    Which is best in terms of sound quality? ease of use? seamless connectivity?
    thx!
  2. #2
    Ghostnyc's Avatar
    Posts
    Global Posts
    305 Global Posts
    Default Re: What is the best dashboard mount and aftermarket car stereo to perfectly integrate with the GS3?
    Regarding mounts - check out the RAM Mount- Military grade windshield mount
  1. What's the best Android tablet and why?
    By eds817 in forum Tablet Chat
    Last Post: 07-17-2011, 06:51 AM
  2. When will Otterbox make a case for Optimus? What is next best case?
    By Nerky in forum LG Optimus S Accessories
    Last Post: 05-29-2011, 02:30 PM
  3. What is this Best Buy ad over forum???
    By Arelunde in forum Motorola Droid X
    Last Post: 12-22-2010, 03:11 PM
  4. What is the best remote wipe and locate app?
    By CPUGEEK in forum Verizon Droid Incredible
    Last Post: 11-25-2010, 12:12 PM
  5. What is your best GTD APP?
    By atlkr5 in forum Android Applications
    Last Post: 09-15-2010, 09:59 AM
