Results 1 to 6 of 6
    enfuego44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery life...good or bad?
    Could you guys look to see if something looks off? Did a factory reset after 4.1.1. On Sprint. Thanks in advance!
    Seems like Android System is burning my battery quicker than it should? Or am I crazy?
    Sent from my SPH-L710 using Tapatalk 2
  2. #2
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery life...good or bad?
    Nothing looks unusual to me - your were down to ~40% battery remaining, after 6 1/2 hours of use in which the screen was on over half the time. I don't know what your brightness setting was but that seems about what I'd normally expect with the screen on for that long.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
  3. #3
    smooth4lyfe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Definitely could be better... Get this app called Juice Defender, it really helps save battery a LOT
    If u don't mind the bulk, get an extended battery which does amazing
    Sent from my Samsung Galaxy S3 Boyyyyyy!
    Archienj7 likes this.
    enfuego44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Screen was at half brightness. When I hit the refresh at the top right on battery stats it says "surfaceflinger". On my wifes s3 it says something else. Is surfaceflinger doing something crazy? Or am I just paranoid?
  5. #5
    Zulu Warrior's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Overall, nothing looks out of place to me. It's usually helpful to post the stats from the display section with any battery troubleshooting too, but I don't think it's necessary in this case. Often the android system will be a high percentage if most of the time you are just scrolling through menu's settings, ect. My phone usually does have much better battery life than that, but recently when I updated to Jelly Bean on this thing, mine's been having a little worse battery life too. I think for now your phone looks fine, let it go a few days and if you still have issues with it, post again on here, but nothing is standing out for now. Just as a comparison, on days when I don't use my phone much at all (A few texts throughout the day, maybe checking some news articles for a few minutes throughout the day, and less than an hour of talk time) I can end a 16-hour day with 75-80 percent battery left. That is with LIGHT use, often I do use it more than that too.
    enfuego44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for chiming in guys. Rhings are looking better today it seems. Ive been on wifi so of course it would. I realized that I was also in a spotty lte location so this may have contributed. Should I just switch to cdma only when I dont need 4g or does it matter? Thanks again!
  1. My battery life. Good or bad?
    By boogalu in forum Samsung Galaxy S3
    Last Post: 08-29-2012, 10:53 PM
  2. Replies: 67
    Last Post: 03-29-2011, 08:17 PM
  3. Is Japanese Earthquake good or bad for us?
    By sun2d in forum The Android Central Lounge
    Last Post: 03-23-2011, 03:20 PM
  4. Replies: 7
    Last Post: 12-31-2010, 03:01 PM
  5. Seidio 1750 maH batteries... good or bad experiences?
    By evolutionary#AC in forum EVO Accessories
    Last Post: 06-28-2010, 01:25 PM
