Results 1 to 6 of 6
    boogalu's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default *#6335623# doesn't work anymore??
    This is the secret menu code used to turn off the pesky wifi notice.. Not that I want to turn it back on... But I can't seem to get back into that menu anymore. Any insight?
  2. #2
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: *#6335623# doesn't work anymore??
    Have you upgraded to Jelly Bean? I think I read some other posts that noted that correlation.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
  3. #3
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something JB
    Verizon pulled the same trick with the rezound awhile back. They hide it so that you have to deal with the pop up. It isn't gone and someone will find it again
    Sent from my X-Band Modem... TY Genesis
    guinnkevinr likes this.
  4. #4
    sal the wop's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check out the app "phone info". It may be what your looking for. It gives you system access....
    Sent from my SCH-I535 using Android Central Forums
    boogalu's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks guys. I haven't updated to jellybean yet.. And luckily I was able to turn it off before they took it away!! SCORE!! just wondering if I did something else to make it not pop up.
  6. #6
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something JB
    Verizon love to do that kinda of stuff
  1. HTC weather widget doesn't work anymore??
    By pontoon78 in forum Verizon Droid Incredible
    Last Post: 11-24-2012, 06:43 PM
  2. GPS doesn't work anymore
    By payterx in forum Virgin Mobile Optimus V
    Last Post: 05-16-2012, 05:35 PM
  3. ShootMe doesn't work anymore?
    By EvilMonkey in forum Android Apps
    Last Post: 01-19-2012, 06:33 PM
  4. Google LISTEN (podcast) app doesn't work
    By EverythingiDont in forum Android Apps
    Last Post: 11-16-2009, 07:36 PM
  5. Google LISTEN (podcast) app doesn't work
    By EverythingiDont in forum Motorola Droid
    Last Post: 11-08-2009, 07:47 PM
