1. Nathan Benefield's Avatar
    Samsung Galaxy S3 Wont connect to my Computer when plugged in by USB.
    Brand New Phone
    The only thing my phone does is charge.
    Nothing happens on the phone.
    Tried when debugging usb was on and off.
    Tried with more than 1 computer.
    Tried using Kies.
    My computer doesn't even realize there is a media device connected.
    All I want to do is be able to access my folders on my mobile via my computer.
    Computer is windows 7 only 2 months old.
    A guy at my work has the same phone and my computer picks up his device.
    Is it likely my phone is faulty?
    Any help will be much appreciated.
    nizar burah likes this.
    12-10-2012 04:03 PM
  2. winmod21's Avatar
    For some reason, my windows 7 didn't either, until I plugged the phones' USB to microUSB cable into a different USB port on my laptop. I didn't try all the ports, but the computerwouldn't pick up my GS2 Skyrocketon the first port I tried. I also remember reading something about unplugging the USB and then plugging it right back in, on either the Samsung/Kies webpages, or on some other Kies related tutorial page.
    Moreover, I've read here in many threads, were member's more in the know about Kies & androids stuff . . often suggest that Kies should be uninstalled, re-installed, and then updated. Plus, to also make sure you're using the cable that shipped with the phone. Hope that may help. Other more knowledgeable member's than I, will be along soon.
    12-10-2012 04:53 PM
  3. JeniferF's Avatar
    Does the guy at work's computer pick up your device?
    I had this EXACT issue. I tried over and over and went on site after site to try to get a solution. I took it into the store I bought it in, he couldn't get it to do it either and they gave me a brand new phone and it worked perfectly.
    12-11-2012 10:24 AM
  4. elisheva60's Avatar
    Brand New Phone
    Tried using Kies.
    I had exactly the same problem though I remember connecting when I first got the phone a couple months ago. I managed to find the phone under "devices and printers". I couldn't open or see any files. But I believe I right-clicked and found the troubleshooter. That determined I needed a driver and installed it. Now everything's working fine and I'm synching my music from windows media player to my sd card on the phone.
    Vilya1980 likes this.
    03-23-2013 11:25 PM
  5. AxlMyk's Avatar
    I use ES file explorer over wifi instead. Works great.
    03-24-2013 12:43 PM
  6. Lacy LeAnn's Avatar
    try using a different usb cable. I had to use the one that came with my kindle. try using one that doesn't have the bump towards the end of the cord (I think it might be a surge protector?).
    04-10-2013 03:19 PM
  7. meyerweb#CB's Avatar
    RFI filter. Shouldn't make any difference, but you're right that a different cable can often make the difference. Also try a different USB port, and try after rebooting the computer.
    But it's worrisome that you can see a different S3. Try going into Developer settings and turning USB debugging on, if it isn't already. Does the phone charge when connected to a computer? When you connect it, does it beep, and display a notification that says it's "connected as a media device"?
    04-10-2013 05:17 PM
  8. Ilya Mochalov's Avatar
    Dear All,
    The problem is in a usb cable - I tried my Kindle cable and everything was great.
    Altough the original usb did work at my job PC with XP on board.
    04-14-2013 01:41 AM
  9. Mark Malone's Avatar
    You are correct that it was the cable. A good ammount of 3rd party cables that are sold are charge-only cables that do not support data transfer. The cable that came with the GS3 supports both. Its worth it to inquire about that function when you're picking up extra or replacement chargers and cables.
    05-09-2013 10:42 AM
  10. myIphone4s's Avatar
    Have you tried switching to camera function mine reads most of the time on the top setting and 100% on the camera setting
    With my monster cable and stock any Ideas on how to fix
    05-09-2013 01:14 PM
  11. Craig Roper's Avatar
    deffinatley a cable issue just swapped mine and now works fine. hope this helps
    05-09-2013 03:21 PM
  12. meyerweb#CB's Avatar
    Samsung makes great phones, but they seem to source their cables from the cheapest Chinese source they can find. There have been more than a few people reporting problems with Samsung cables.
    05-09-2013 05:46 PM
  13. Moy Ainsbury's Avatar
    I had the same problem and this solution worked - Joy! (also tried plugging into a different USB port just in case). Thank you muchly :0)
    05-13-2013 05:42 AM
  14. interpreter50's Avatar
    Thank you indeed. I used the charging cable as data transfer cable but it did not work. Then I found my son's data transfer cable (Galaxy SII) that was in the telephone box. It worked fine. One more happy android central forum member :-)
    05-31-2013 11:48 AM
  15. George Knight's Avatar
    i had the same trouble with my s3 mini but a changed to my old htc cable and that worked thanks for the help
    12-09-2013 02:57 PM
  16. Denice wood's Avatar
    i have a galaxy 3 . it wont connect to my google chrome hp lapop. im wondering is it my pc. can someone help
    03-05-2014 07:25 AM
  17. GSDer's Avatar
    It's most likely the cable that you're using. Are you using the original Samsung cable that came with the phone?
    You may just need to purchase a new data cable (be sure it's not just a charging cable).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
    03-05-2014 10:12 AM
  18. Jeye Daye's Avatar
    For anyone still having trouble beyond the cable, and beyond turning on USB debugging in developer mode, I stumbled upon this and it worked for me...sort of. My Mac acknowledges the phone now, and I can see MOST of my files... Android.com
    03-23-2014 05:17 PM
  19. GSDer's Avatar
    Welcome to the forums and thanks for posting your solution! We don't get many Mac solutions so yours is very welcome.
    You could try something like AirDroid: https://play.google.com/store/apps/d....sand.airdroid if you want to do away with the cable or if there are files that you're still not seeing.
    03-24-2014 12:22 AM
  20. cbgerman's Avatar
    Issue: PC WIN 7 wouldn't see phone or show USB options when connecting via USB
    Solution:
    Using same cord and port on computer.
    Unplug cable
    Remove Battery
    Remove SIM
    Reseat SIM
    Reseat Battery
    Restart Phone
    Plug cable back in original port
    From Drop Down Notification Setting at Top of Screen Select USB Computer Connection
    Select Media Device (MTP)
    04-29-2014 07:30 PM
  21. Thomas White4's Avatar
    That actually worked, I had driver restore pop up and tell me that my driver was out of date, but just clicked continue and it all worked as normal.
    03-03-2015 08:31 AM
  22. Vilya1980's Avatar
    It helped me, thank you!
    07-24-2015 12:52 PM
  23. Vilya1980's Avatar
    This post helped me, thank you
    07-24-2015 12:53 PM
  24. Aly B's Avatar
    Thank you so, so much! All I had to do was try an opposite USB port on the other side of my Dell laptop. I can't believe I spent so many months and money (to test different cables) when the solution was so simple. I will remember this lesson.
    08-29-2015 01:45 PM
  1. Samsung Galaxy S3 is unable to connect to exchange 2010
    By bensaslo in forum Introductions
    Last Post: 07-08-2012, 08:47 AM
  2. My tablet wont mount to my computer
    By EerieCrate in forum General Help and How To
    Last Post: 02-02-2012, 07:44 AM
  3. my tb isn't connecting to my computer
    By mikah15 in forum Verizon HTC Thunderbolt
    Last Post: 08-23-2011, 11:41 AM
  4. How Do I Connect to My Computer?
    By samsungepic85 in forum Sprint Epic 4G
    Last Post: 06-25-2011, 05:37 PM
  5. Can't get my X to connect to my computer anymore!!
    By GTRDEALER in forum Motorola Droid X
    Last Post: 09-22-2010, 06:11 PM
