- 01-18-2013, 11:18 PM #26
- 01-19-2013, 12:16 AM #27
- 01-19-2013, 01:02 PM #28
Re: Samsung Galaxy S3 will not turn on
Kelly, you're the one who made the statement, and then posted a link as support for that statement. If you're going to do that, at least post one that actually supports your point. Just sayin.
Your last post doesn't address the same issue, I don't think. This is still talking about the expoit.. I've not see any evidence that the bulk of phones which have succumbed to "sudden death" were attached by some malicious hacker. People set them down, and picked them up later to find them dead. I still think the exynos exploit and the rash of dead phones are two separate issues.PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 01-19-2013, 01:39 PM #29
Again, not my job to go researching and my last post does very well address it. Yes, I know about it charging overnight in most cases and then it is dead..got it. Yes, Samsung has looked into this and as they have been clear about:
They have found the Sudden Death is caused by the Exynos issue, it also has allowed apps to exploit this vulnerability. Which means it doesn't have to be a hacker hacking into your phone.Samsung is beginning to roll out a security patch to UK Galaxy S3 phones, designed to clear up a bug in the S3's Exynos chip that could potentially see some phones being wiped or bricked by naughty hackers.
The sudden death bug, as it's known, was found by an XDA Developers user and gives hackers access to the RAM of phones including the Galaxy S2, S3 and Note. "RAM dump, kernel code injection and others could be possible via app installation from Play Store," user alephzain explains.
When someone is having the issue with Sudden Death, I'm expecting they know a bit about it. Then if I post something to them about it and they aren't really familiar with the Sudden Death, I expect questions. You aren't having this issue, you are just worried about critiquing me. I'm not a writer here, I'm not an adviser here, I'm not an educator here, I am a user. It is not my job to go educate someone on every aspect of something they ask about and assume they know nothing about it when they post a question. They post a question, there is more, fine, they post something else and then we can get deeper into it. What I find interesting is that you are not even the one with the issue, yet you are the one trying to tell me that I need to put out the info from beginning to end on this issue.
Nope, that's not how it works. People ask questions, you give them some info, if they don't understand or need more info, they post another question. - 01-19-2013, 02:48 PM #30
- 01-19-2013, 02:56 PM #31
- 01-19-2013, 03:22 PM #32
- 01-19-2013, 03:31 PM #33
Hmmm...sounds like a totally different issue than Sudden Death, because with that, it's just completely dead. I've seen some stuff about this where rooted devices are concerned.
Quick search and I found this on a non-rooted device. Look through this and see if there is something that will work for you here.
If none of this work, you might want to start a thread with a good description in the thread title and then more will see it that might can help. I don't root at all, so not familiar with any of that and I have read about some issue here for non-rooted devices that the people that do a lot of rooting, know how to fix. - 01-19-2013, 03:37 PM #34
Just registered after reading through all/most of the threads....Mine has just died not rooted i was using it loaded skype and it just hung had to remove battery and now stuck on logo..
After doing a bit of research would reloading firmware using odin be of any benefit? I cant get into factory reset i.e home power and vol up but i can get into custom firmware load so use odin and load original firmware? - 01-19-2013, 03:51 PM #35
- 01-19-2013, 04:00 PM #36
- 01-19-2013, 04:11 PM #37
- 01-19-2013, 04:19 PM #38
- 01-19-2013, 04:20 PM #39
- 01-19-2013, 04:21 PM #40
- 01-19-2013, 04:29 PM #41
- 01-19-2013, 04:38 PM #42
Just from what I'm reading, the Odin and flash seems to work, but..also, seems like this would be honored by Samsung if there is a Samsung store or your carrier replacing it.
Also, one thing I saw was to remove the SD card if you have it, then try to turn it back on. - 01-19-2013, 04:49 PM #43
While this thread is about Gingerbread and someone trying to root their phone, just scanning this, I see there is possibly some kind of help using Kies. Might want to read this thread, check out one of the links about restoring using Kies that is at the beginning of this thread.
Also something I didn't think about, if y'all have "tech" stores where you are that will reflash your phone, might be a very good idea to do also.
Here's the thread I just saw, if you read through, you might find you can do the same thing with Kies and the S3:
- 01-19-2013, 04:53 PM #44
I talked to Samsung support but no joy. They won't help me because the country where I live does not show up on their country list. I bought the phone in the USA and wasted an hour on the phone with USA support.
I am curious to see if flash would work.
One thing seems to be sure, Samsung is not going to replace anything for me at this point in time.
Sent from my Nexus 7 using Android Central Forums - 01-19-2013, 04:56 PM #45
- 01-19-2013, 04:56 PM #46
- 01-19-2013, 04:59 PM #47
- 01-19-2013, 05:12 PM #48
- 01-19-2013, 05:14 PM #49
- 01-19-2013, 05:18 PM #50
Xoom will not turn on
By FireGuy303 in forum Motorola XoomReplies: 28Last Post: 03-18-2013, 02:24 PM -
Droid's Screen Will Not Turn On??
By GAlex067 in forum Motorola DroidReplies: 4Last Post: 01-19-2011, 08:22 AM -
blackflip will not turn on!!!!!!1
By bigheadtony6 in forum Motorola BackflipReplies: 2Last Post: 11-04-2010, 04:02 PM -
Inc will not turn on, no charge light
By superstar in forum Verizon Droid IncredibleReplies: 3Last Post: 09-23-2010, 10:29 PM -
Phone will not turn on
By kvaughan#ac in forum Verizon FascinateReplies: 4Last Post: 09-14-2010, 08:39 AM
Reply
