06-24-2015 01:57 AM
229 ... 23456 ...
tools
  1. Celine Costa's Avatar
    it turned on but it will stay frozen at the name samsung.
    i pressed the volume down button, the home button and the power button at the same time to try and fix it, but is sends me a message saying
    "Warning: a custom OS can cause critical problems in phone and installed applications. If you want to download a custom OS, press the volume up key. Otherwise, press the volume down key to cancel."
    What is a custom OS ? btw im from canada
    03-30-2013 01:42 PM
  2. DroidXcon's Avatar
    Do the same thing but hit volume up instead of down. And then clear cache. If you have your data backed up you can do a factory reset
    From my Galaxy Note 2 via Tapatalk
    03-30-2013 03:26 PM
  3. DroidXcon's Avatar
    it is a custom operating system. There are developers who take samsungs software and rewrite it the way they like it. Or they take stock Android and load it to the device with some modifications... These custom OS's are called custom ROMs by tech community
    03-30-2013 03:30 PM
  4. meyerweb#CB's Avatar
    Did it ever turn on
    And what changes have you made to the phone? Apps installed? Tried to root? Anything else?
    As a first step, try pulling the battery, wait for a few minutes, and try again.
    03-30-2013 05:09 PM
  5. delmont's Avatar
    I am also from Canada. I had my S3 for five months. All of a sudden while I was taking a video picture, the phone shut off, tried to turn it on but kept on freezing on Samsung galaxy S3 logo. I tried the power, home and volume down buttons and got the same message. I took the phone to WIND authorized repair centre. They refused to fix it telling me that the phone is rooted which is B.S. I know for a fact that i never rooted the phone, not even updated the firmware, Just a stock with no upgrade. I am going to send it to Samsung and let them have a look.
    I would love to hear from the people who had the same issue and if they resolved this problem with Samsung warranty. Any response would be appreciated.
    04-13-2013 07:11 PM
  6. braisthenexy's Avatar
    Hi,
    I am facing the exact same problem as yours...were u able to find a solution for this?
    04-17-2013 09:08 PM
  7. meyerweb#CB's Avatar
    Hi,
    Exactly the same as who's? There are lots of posts in this thread. Please describe your problem, and what you've done so far to try to fix it, and we can try to help.
    04-18-2013 11:19 AM
  8. Mom2Ninjas's Avatar
    Happened to my daughter's phone. We had to get Sprint to replace it.
    04-19-2013 08:36 PM
  9. breda Alice's Avatar
    My s3 Died last nite and wouldn't Turn on , So charged it over nite still wouldn't Turn turn on . Asked friend with same phone could i try their battery but phone still wouldn't Turn work. It's dead
    04-20-2013 10:05 AM
  10. meyerweb#CB's Avatar
    Time for a warranty claim, I'm afraid.
    04-20-2013 01:17 PM
  11. RAvEcREAToR23's Avatar
    hello my s3 was rooted but it worked ok without problems i not used superuser nothing changed ...but today i left him on in my files where all folders seen not locked screen was on when after time he locked himself or just screen go black it dead . removed battery then put in not helped turn on . i tried charge nothing red light not on . tried press up home and power nothing ... maybe where i buy phone they will replace by other ? or can do something to revive s3 ?
    04-24-2013 05:34 AM
  12. meyerweb#CB's Avatar
    If you can't boot into recovery (volume up, home, power), and the phone won't take a charge, I don't think there's much you can do other than return it for warranty service. If you know someone else with an S3 you might want to try a different battery, just in case that's the problem.
    04-24-2013 01:18 PM
  13. RAvEcREAToR23's Avatar
    yes phone dead not shows signs of life even up + home + power ... yes i try return s3 as it looks like completely new not scratched not broken ...and it is sad as my galaxy ace works ok longer time . someone said their samsung stops at logo and nothing . so this was with my galaxy ace and i know 100 % why phone stopped at logo =) somehow i did phone memory 100% and to free space i restarted after that it stopped at logo as memory was 100% full . then when i did factory reset i managed turn on my ace ...
    04-24-2013 04:42 PM
  14. yousof23's Avatar
    Hey, my galaxy s3 wont turn on but when i press the volume down, home and power button at the same time a message appears that says " your os is in critical condition" then it shuts back down.... What should i do now?
    04-25-2013 11:18 PM
  15. meyerweb#CB's Avatar
    That's a new one! Can you boot into recovery (volume UP, home and power)? Are you rooted?
    Assuming you're not rooted, and can boot into recovery, you use the volume up / down buttons to select from the menu, then the power (Or is it home? -- if one doesn't work, try the other. ) button to select the chosen option. I'd suggest trying to clear cache first, and then reboot. If that doesn't work (and I suspect it won't), then you're faced with a factory reset.
    04-26-2013 10:20 AM
  16. RAvEcREAToR23's Avatar
    so i bringed phone where warranty fix maybe not only samsung but all phones they fix ... and they fixed my s3 and say it was not my foult it was some detail in phone broken ...
    04-29-2013 04:23 AM
  17. meyerweb#CB's Avatar
    Glad you were able to get it fixed!
    04-29-2013 08:42 AM
  18. prasannagd's Avatar
    Hi
    My S3 is stuck on the initial screen that says Samsung Galaxy S3 GT-19300. If I press the on/off button nothing happens. If I press it for a long time it the screen goes off for about a second then the same screen appears. I tried taking a battery out put it back in switched on and the same screen appears. Hard reset wont work (Volume up, power button and Home button). It turned on but it will stay frozen at the name Samsung.
    I repeated same and I pressed the volume down button, the home button and the power button at the same time to try and fix it, but it gives me a message saying "Warning: a custom OS can cause critical problems in phone and installed applications. If you want to download a custom OS, press the volume up key. Otherwise, press the volume down key to cancel."
    I pressed volume up key, It says: downloading. do not turn off target!!
    The screen is frozen even in this screen, Please help me to rectify this problem..,
    04-30-2013 12:28 PM
  19. meyerweb#CB's Avatar
    That key combination (vol down, home, power) puts the phone in download mode. The intent is that you connect it to a PC running ODIN, and can use ODIN to download a new ROM or other system files to the phone.
    What you probably want is recovery mode, which is volume up, home, power. As soon as you see the Samsung logo, release all three buttons. If you've timed it right, the phone should boot into recovery. If you release the buttons a little too early or too late, the phone will try to boot normally.
    Once you get into recovery, use the volume keys to select an option, and the home key (I think....if that doesn't do anything try the power button) to execute the selected option. You probably need to select Factory reset.
    04-30-2013 01:20 PM
  20. ladybug's Avatar
    My samsung galaxy s3 feel yesturday on the side walk, it cracked but I was still able to use it. Now today when I went to use my phone the screen is black, I tried turning it back on and it will just vibrate like the phone is still on, I turned up the volume to see if my phone is still on, and it is, but my screen is black, nothing shows up.
    05-08-2013 06:55 PM
  21. meyerweb#CB's Avatar
    I'm really sorry to hear that, ladybug. The LCD is damaged, and there's probably nothing you can do at this point but repair or replace the phone. If it's not pin or pattern locked, you can probably connect it to a PC and copy off any files you need.
    05-08-2013 07:51 PM
  22. clangywangy's Avatar
    Im currently having the same problem with my s3 too. Saw that there was an update so I updated the system. Im just not sure what version it is. After downloading the update earlier, i installed it and then my phone got stuck in the samsung logo. I tried to press the power button for a long time, tried removing the batteries, the volume down+menu+power thing and still my pone opens up to the samsung logo only. Is there anything else that can be done to spare this phone?
    05-11-2013 07:50 AM
  23. meyerweb#CB's Avatar
    What version of the S3 (e.g., what carrier, or unbranded international) do you have. What update did you try to install, and what instructions did you follow (post links). It's never a good thing to manually apply an update if you don't know for sure what it is. If you're lucky, the ROM didn't actually install, and a factory reset will fix it:
    Turn the phone completely off (this won't work if you start with the phone on). Press and hold volume UP (not down)+home (not menu)+power. Hold all three until you see the Samsung logo, then let all three go immediately. If you get it timed right, the phone will boot into recovery. If you release the buttons a little too soon or too late, it will try to boot normally. Just turn the phone off and try again.
    Once you're into recovery, use the volume buttons to select Factory Reset, and the home button (or maybe it's the power button, I don't remember--if home doesn't do anything, press power) to execute it.
    If you can't get into recovery at all, or a factory reset won't help, you're going to have to try to boot into download mode, and try to load a complete, stock factory ROM. To help you we'll need to know what version of the phone you have.
    05-11-2013 05:02 PM
  24. Jerex Garcia's Avatar
    I try to install a jelly bean in my samsung galaxy y but when i strt installing it after the reboot it freeze in samsung galaxy y logo. i try the volume up + home + power on but still it only shows the samsung galaxy y logo. do you know other way to recover my phone? please help thanks.
    05-11-2013 11:15 PM
  25. meyerweb#CB's Avatar
    Jerex, did you turn the phone off before trying UP+Home+Power?
    If you did, then you're probably releasing the three buttons a little too early or a little too late, or not pressing them all at the same time. Start with the phone off, press and hold all three buttons together (you can't press one first, then the others), and as soon as the word Samsung appears let go of all three buttons.
    05-12-2013 03:35 PM
229 ... 23456 ...
  1. Xoom will not turn on
    By FireGuy303 in forum Motorola Xoom
    Last Post: 10-31-2013, 08:17 AM
  2. Droid's Screen Will Not Turn On??
    By GAlex067 in forum Motorola Droid
    Last Post: 01-19-2011, 08:22 AM
  3. blackflip will not turn on!!!!!!1
    By bigheadtony6 in forum Motorola Backflip
    Last Post: 11-04-2010, 04:02 PM
  4. Inc will not turn on, no charge light
    By monkeymisfit in forum Verizon Droid Incredible
    Last Post: 09-23-2010, 10:29 PM
  5. Phone will not turn on
    By kvaughan#AC in forum Verizon Fascinate
    Last Post: 09-14-2010, 08:39 AM
