06-24-2015 01:57 AM
229 ... 34567 ...
tools
  1. swagnotesrobert's Avatar
    My samsung galaxy s3 was working perfectly. then one day it started turning off by itself. i never dropped it or anything. i tried turning it on it would just go to the samsung logo and then just turn off. it just keeps doing that. help please i need my cell phone
    Philipo Mabula likes this.
    05-17-2013 09:29 PM
  2. anaisbett's Avatar
    Hi. Ive got exactly the same problem. Both my mobile phone provider and Samsung themselves want nothing to do with it as they think ive rooted it myself which is BS. My only option now is to try to get my phone replaced by my insurance company.
    Ill never buy samsung again
    Thanks.
    05-19-2013 09:50 AM
  3. meyerweb#CB's Avatar
    With the phone off, try to boot into recovery: press and hold, at the same time, the volume UP, home and power buttons. Hold them until the Samsung logo appears, and immediately release all three buttons. If you see a menu, use the volume up and down buttons to select Factory Reset, then press the power button to execute that choice.
    Robert, if your phone really started doing this all by itself, I'd take it back to where you got it and see if they can get it working, and if not have it repaired under warranty. Unfortunately, sometimes products are defective. Not just Samsung products, either.
    05-19-2013 10:07 AM
  4. srinivas9992's Avatar
    Hi
    I'm facing the same problem with my S3now.. My phone was working fine till night and now in the morning when i woke up nothing works.. It just looks the screen is dead. i tried everything home key, volume keys and even removed and kept my battery for couple of time, there is no change. SUPERUSER is installed in my S3, is there anything that i can do to make my S3 work normal again.. Pls help.. thank you in advance
    05-19-2013 10:33 PM
  5. TheChic's Avatar
    Thank you!!!!! My AT&T non-rooted Galaxy S3 (new in 1/13) was having force close issues too often then one day just stopped at the SAMSUNG word after the rain drop screen during boot. It displayed SAMSUNG for hours. I had removed battery. Powered off and on, etc., nothing would get it past that point. After reading your instructions, I got it to the menu where I could do a factory reset and now it is working!!! Thank you SO SO MUCH!
    05-20-2013 07:27 AM
  6. meyerweb#CB's Avatar
    Hi
    srinivas, have you tried the instructions in the post immediately above yours, to boot into recovery? If that doesn't work, then I'm afraid there's probably nothing you can do other than have the phone repaired, hopefully under warranty.
    05-20-2013 07:31 AM
  7. mentomazing's Avatar
    I have really messed up I tried rooting my galaxy s3 with odin and it told me it failed so i turned it off. when i tried to turn it on it would just vibrate and nothing would happen.
    05-23-2013 07:51 AM
  8. Justin Goble's Avatar
    Hi, I have a Samsung Galaxy S3 from sprint, and I just recently attempted to apply the 4.2.2 update (I believe it was 4.2.2, update after 4.1.2) and now it gets stuck at the flashing "Samsung" screen and won't go any farther. I have rooted it and the update automatically updated for some reason after I pressed "Install Later". I tried booting into recovery mode, then tried both deleting cache and doing a factory reset, and it still gets stuck at the same spot.
    05-23-2013 03:25 PM
  9. meyerweb#CB's Avatar
    Still 4.1.2, but with Premium Suite features added, and new modem software.
    OTA's and rooted phone don't play well together. Are you running a custom recovery (Clockwork Mod or TWRP)? If so, I would suggest following the directions in post #2 of this thread: Your way to update to MD4 This will get the latest Sprint ROM and modem on your phone.
    If you're still on the stock recovery, I would suggest installing TWRP: How to Install TWRP Recovery on the Samsung Galaxy S3 (Sprint) - TheUnlockr and then do post #2 in the above thread.
    05-23-2013 04:36 PM
  10. nate6978's Avatar
    Samsung will actually fix it for free cause its some kind of flaw so they are talking in all phones and fixing under warranty no matter hoiw long or even if its rooted.
    05-23-2013 04:53 PM
  11. nate6978's Avatar
    Samsung will fix for free just go to there website and talk to a representative bout it and they will set you up and give you the ups label to send it in for repair even if its rooted cause there are a lot of s3 messing up cause software problems so its a free fix I did it myself and I had my phone rooted and everything.
    05-23-2013 04:56 PM
  12. Ashwin Prasad's Avatar
    hello folks, I own a s3, rooted, and like most of you, i rebooted by phone once and it froze at the logo part. after a while, the power button stopped working. the I didi find a way to fix it.
    for all those having a problem with their power buttons: try this.
    1. Disconnect the usb/power cord from the device.
    2. Remove back cover from the device.
    3. Remove battery, and leave the back cover off. You will place the battery back-in in a second.
    4. Reconnect the usb/power cord to the device and then to your PC.
    5. Now, while the device is connected, plugin the battery. This is the key step.
    At this point, the device shows the battery charging animation, the black/white one on fullscreen, the one that is shown when the device is powered-off and charging. The device had not shown this image in a very long time, while the power button issue was going on, so this looked promising.
    6. Now, I pressed the power button, and then the phone started to boot-up.
    7. I then went inot downloading mode, flashed it again with the default OS and it was good as new.
    I eventually did get bored and I rooted it again and havent had any problems since.
    And thank goodness I had all my data backed up in the ext sd card.
    hope I helped.
    source: androidforums
    05-23-2013 11:30 PM
  13. loonie01's Avatar
    05-27-2013 06:00 PM
  14. danielle bush's Avatar
    Hi people
    Last night my samsung s3 phone did a firm wear up date , and now it will not turn on , i have tryed the three button trick but it is still not working .any advise ???
    05-27-2013 10:17 PM
  15. loonie01's Avatar
    I'm going to call samsung about my S3 in the morning. I'll report back on success or failure.
    05-28-2013 12:16 AM
  16. Davaneisha Bowie's Avatar
    I have a Samsung galaxy s3 with AT&T. I recently rooted my phone it worked for about a day and it rebooted on its own and when it rebooted it stayed on the Samsung sign with the glowing ring.. that's the furthest it go.. I need help on how to get my phone back on...please help...yes I already did the recovery mode and wipe and cleared everything it still won't come on...please I need all the help I can get..thanks in advance
    05-28-2013 05:08 PM
  17. meyerweb#CB's Avatar
    Hi people
    Did you turn the phone off before you tried to boot into recovery? It won't work with the phone on.
    05-28-2013 10:16 PM
  18. meyerweb#CB's Avatar
    Can you boot into download mode? If so, you should be able to use Odin to install a valid ROM. This post will get you back to stock unrooted, and then you can root again: [Guide UPDATED] How to Unroot your AT&T Galaxy S3 (Return To Stock I747UCDLK3 JellyBean )
    You won't be able to do the triangle away step, but if you're going to root again, that won't matter.
    If you can't get into download mode, I'm not sure what to do.
    05-28-2013 10:22 PM
  19. Sonal89's Avatar
    My Samsung Galaxy S3 is in warranty.. Its not turning on.. 4 months old.. Is it possible to replace with new one...
    Any help wil be appreciated.. thanks..
    06-01-2013 04:33 AM
  20. meyerweb#CB's Avatar
    You're going to have to contact Samsung directly. Since it's still in warranty, they will replace it, probably with a refurbished phone.
    06-01-2013 02:31 PM
  21. letsgotowawa's Avatar
    I have a tmobile galaxy s3 (Sgh-t999). I was flashing Sonic Team ROM @ FreeGS3 ROM - TheUnlockr and after I installed it I cleared dalvic cache as usual and hit reboot phone now. When it shut off it never came back on. Home, up, power and home & down do nothing. If i take out the battery and plug it in i can get the red light to go on but thats about it. Do you possibly have any suggestions for me. I have flash about 20 different roms on it with no issues. Usually i use Jedi Invasion 5 as my ROM but tried this one/. I would appreciate any help you may be able to give.Thank you
    06-02-2013 10:49 PM
  22. wes75's Avatar
    My wife's galaxy s3 had a pop up saying unfortunately Samsung sync adapters have stopped. Now the phone will Not stay turned on. At&t said it is under warranty but she's trying to save all her pics to the pc but the phone won't stay on long enough to sync. Is there anyway to salvage the phone?
    06-03-2013 10:16 PM
  23. wes75's Avatar
    My wife's galaxy s3 had a pop up saying unfortunately Samsung sync adapters have stopped. Now the phone will Not stay turned on. At&t said it is under warranty but she's trying to save all her pics...Is there anyway to salvage the phone?
    06-03-2013 10:27 PM
  24. zrxoa1's Avatar
    Hi people
    Same exact thing here. I am sending mine into Samsung to be looked at...
    06-04-2013 02:55 AM
  25. magicgoo's Avatar
    Hi I am having the same problem - after taking a video my Galaxy S3 just shut down and will not charge properly. If I put my friend's battery in it manages to get to the "Samsung" Logo start up page but then freezes on it and can't go past it. My only problem is, I have all of my photos saved on the phone memory. At CarphoneWarehouse they told me they can send it to repair as it's under a warranty but their repair service wipes out all the data. Is there any way that I can try and save my things? Would recovery mode mean that there is a chance of saving the phone or does it mean complete reset?
    06-04-2013 01:06 PM
229 ... 34567 ...
  1. Xoom will not turn on
    By FireGuy303 in forum Motorola Xoom
    Last Post: 10-31-2013, 08:17 AM
  2. Droid's Screen Will Not Turn On??
    By GAlex067 in forum Motorola Droid
    Last Post: 01-19-2011, 08:22 AM
  3. blackflip will not turn on!!!!!!1
    By bigheadtony6 in forum Motorola Backflip
    Last Post: 11-04-2010, 04:02 PM
  4. Inc will not turn on, no charge light
    By monkeymisfit in forum Verizon Droid Incredible
    Last Post: 09-23-2010, 10:29 PM
  5. Phone will not turn on
    By kvaughan#AC in forum Verizon Fascinate
    Last Post: 09-14-2010, 08:39 AM
