Page 9 of 9 FirstFirst ... 6789
Results 201 to 223 of 223
Like Tree5Likes
  1. #201
    Default Re: Samsung Galaxy S3 will not turn on
    I have the exact same issue mentioned a dozen posts back or so where the red LED comes on when you plug in the charger with no battery. Nothing works. I called Samsung, they will NOT good will the repair for an out of warranty phone (contrary to what somebody posted on page 2 or 3). Repair costs are $70.36. Even worse they WILL wipe all the data on the phone, even if the repair can be fixed without wiping anything. "It's for your privacy protection". If I could find some info about the cause/fix, I might attempt this myself (I've fixed iPhones before, replaced cracked screens, etc) but I haven't been able to find a specific fix for this red LED problem
    Update:
    After looking around, it appears the mainboard is difficult to source. The part alone on eBay is twice the cost of paying Samsung to do the work. I also checked places like ifixit and looked for other repair places, but seems they are only offering screen replacements. I guess I have no practical choice but to let Samsung to the work.
  2. #202
    I had an issue with my S3 today. I dropped it about mid afternoon, but the phone worked after I dropped it. I was driving back to my shop and never got a phone call or text, thought it was odd as I just texted my wife, but did not check my phone. I checked my phone two hours later, seemed to be dead. I thought maybe the battery died, but I never saw the red light blink, nor heard the phone yell at me. Still pondering the idea that it may be dead, I plugged it into a charger (Galaxy Note 1 charger) and it would not show any signs of charging or turning on. I pulled the battery and waited a minute or so, plugged batter back in, did not press any buttons, and the phone went to the 'Samsung' and then the 'Samsung Galaxy S3' logos, but not the secondary 'Samsung' logo with animation nor the AT&T logo.
    I tried all the hard resetting, debug mode, and plugging in while battery out stuff. I was upset when I read in this forum that some people thought the phone needed replacement. I started doing anything I could to get the phone to work. I tried taking battery out and plugging in the charger, but a red notification light came on for about three seconds and went off. Nothing seemed to work.
    I DID finally get my S3 to WORK!
    What I did was, unplugged from charger, took out battery, took out sim card and micro SD card, plugged charger back in, replaced battery. The phone did a full cycle and was working again, all I had to do was put my sim card and SD card back in and restart the phone. My battery was at 58% so no, the battery did not die and get 'just enough juice' to turn on after this period.
    Thanked by:
    GSDer
  3. #203
    Hi there, wondering if someone could help, i was using my phone earlier and playing words with friends when my phone crashed and switched off, I have been unable to switch it back on. I have tried taking the battery out for a while, tried charging for a while (my phone doesnt seem to recognise being charged and nothing appears on the screen ie. the battery image). My phone just isnt responding to anything. I tried the hold the volume (up and then down), the power and home button but nothing happened, Im really annoyed as the phone is not just outwith the warranty period. Can anyone offer any suggestions, other than forking out alot of money by taking it back to the retailer or sending off to samsung directly?
    Thanks
  4. #204
    I had to send mine to samsung. $75. The mainboard had died.
  5. #205
    Quote Originally Posted by Ann-Marie Adam View Post
    Thanks
    Try what I did, take out your Sim card if you are on ATT or Tmobile, I dont know about verizon though, they don't use sims. Then try to start the phone. If it starts, replace the sim and restart the phone.
  6. #206
    This problem exactly happened to my galaxy S3, I found out that the power button/ lock screen button was broken. I took it to tmobile and they said that this type of issue doesn't just happen, that it is from so much constant use. I hope you get it to work! Good luck!
  7. #207
    Red face Re: Samsung Galaxy S3 will not turn on
    Great!!! My phone works again....
  8. #208
    I tried the same but dosen"t helped me. Logo of samsung GT-I9300 appears for approx 4 seconds and goes blank for approx 2 second than again samsung logo... this continues. Nothing worked for me. when charging, battery icon of "starting charging" appears and this icon same as samsung logo, goes back and comes again. Please help
  9. #209
    Quote Originally Posted by jvbhatt18 View Post
    If you take the battery out and reinsert it (without pressing any buttons), does the phone begin to boot up by itself?
    When the phone is completely off, if you connect a charger you should see a static battery graphic, followed by a different graphic showing the current battery level and charging activity. The screen should turn off after about 30 seconds while the phone continues to charge.
    Can you boot into Recovery mode or Download mode? Here's how:
    - you use Recovery mode to clear the system cache and to Factory Reset
    - you use Download (aka Odin) mode (showing the Android guy) to load/reload firmware
    - the key sequences to enter both modes are very similar, and they are timing dependent so it may take a few tries to get it working
    -- Recovery = Volume Up + Home + Power
    -- Download = Volume Down + Home + Power
    - for either, you start with the phone completely off
    - press and hold the required keys simultaneously, and release them all when you see the swirling logo (not the static white text)
    Try Recovery mode first (use the Volume rockers to navigate; use the Power button to select) and if it boots into this mode just clear the cache and then restart. If the phone doesn't boot into Recovery mode then try Download mode.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  10. #210
    I'm having an issue where my galaxy s3 won't turn on at all. It won't even show the startup logo, just a black screen. doesn't come on and it still doesn't start up. I've even tried rebooting it: holding down the power button, volume up button, and the menu button at the same time, and also same combo with volume down still nothing. Yes I have tried a completely fresh working battery also ITs a T mobile version, when plugged into charger it does show the the charging graphic and appears to be taking a charge. It's also has a red led light on at times. Am I completely screwed, I took it in but the store was no help they just would send out and give a refurb. I would like to fix it or at least recover my pics and things. I may take apart to see if something is loose but any help would be appreciated
  11. #211
    Quote Originally Posted by rynotronic View Post
    So, it's not making any sounds either?
    You could try purchasing a JIG, which will force it into Download mode (if at all possible).
    Or you could try a JTAG service (ex. http://mobiletechvideos.mybigcommerc...-brick-repair/) - I can't tell you if they can save your data (I'm guessing not) but they may be able to get it working again.
  12. #212
    so I have a galaxy s 3 and I factor and restarted it then when the options came I said reboot but now when it gets to the Samsung logo nothing happen its been like this all night I don't know what to do I need my phone and I cant get a new one anyone help me please
  13. #213
    Quote Originally Posted by Annie Brown1 View Post
    Welcome to the forums!
    If you take the time to read through this thread you'll find many suggestions on what to do, rather than us having to regurgitate the information over-and-over again for each new person that comes along.
    It's also generally helpful if you list the phone model number (it can be found under the battery if you don't still have the box), the carrier (AT&T, etc) the firmware version that was on there (4.3, 4.1.2, etc) and your country (if an International user).
    Also useful is some background information - why you did the Factory Reset; will the phone boot into Recovery mode or Download mode; etc.
  14. #214
    Hoping someone can help me
    I have read through all this thread and cant get my phone working
    I have the Galaxy S3 GT-i9300
    it did an update and then gets as far as the screen
    Android is updating
    Starting Apps
    I have gone in to the recovery mode and cleared Cache and Factory reset
    Cant get kites to read the phone
    At a loss as to what to do next
    Some one please help :-)
  15. #215
    Quote Originally Posted by nicnack31 View Post
    Cant get Kies to read the phone
    Are you using Kies v3? If your phone received the update to 4.3 then you'll need to install the new version of Kies (just Google it).
    Also, don't worry if Kies doesn't recognize the phone - that's pretty normal if the phone isn't booting properly. Just select the second item in the Tools menu (Firmware upgrade and initialization) and go through all of the steps.
    Thanked by:
  16. #216
    Android is updating
    Starting Apps
    Ps I am not very technical was amazed i found the reboot mode
    Really hoping someone can help me
    Thanks in anticipation
    Nic
  17. #217
    Quote Originally Posted by GSDer View Post
    Welcome to the forums!Are you using Kies v3? If your phone received the update to 4.3 then you'll need to install the new version of Kies (just Google it).
    I have downloaded the Kies V3 and that then says i need a 2.0data cable
    Are all data cables not the same ? Will try again though
    Thanks so far
  18. #218
    Thumbs up Re: Samsung Galaxy S3 will not turn on
    It worked Thank you so much
    I wasnt getting it into downloat mode I was going into the re boot mode
    Phone working and for now running better than ever
  19. #219
    HELP!
    I have an SIII. It was originally for AT&T, I had it unlocked from samsung for T-mobile. I've used it fine for the past 3 or 4 months. About a week ago it shut off. Wouldn't do anything. I was told the phone was fried. My four year old dropped it a day ago and it came back on for a few hours. I don't know what happened but it started to do the shutting off thing again. Originally it would only power on to the samsung screen then instantly shut off again. Today it won't do anything but it has started vibrating with small pauses in between each one and won't stop. I pulled the battery then put it back in. Same thing. Any ideas?
  20. #220
    Last night I factory reset my phone. now my phone has been stuck on the flashing Samsung screen for over 12 hours and I have no idea what do to. help me
  21. #221
    Quote Originally Posted by CaityReed99 View Post
    You can start by taking the battery out for a few minutes and then reinserting it. Try powering the phone on normally. If that doesn't work then long-press the Power button until the phone turns off. Then try booting into Recovery mode and Download mode to see if either of those will work:
    - press and hold the required keys simultaneously, and release them all when you see the desired screen
    If it won't boot into Recovery mode then try Download mode. If that works then just long-press the Power button to turn the phone off and get back to us with your model number/carrier/region/firmware version.
  22. #222
    Welcome to the forums!You can start by taking the battery out for a few minutes and then reinserting it. Try powering the phone on normally. If that doesn't work then long-press the Power button until the phone turns off. Then try booting into Recovery mode and Download mode to see if either of those will work:
    Hi, I have kind of the same problem, although my phone has fallen around 5 months ago and has a tiny bit of crack on the screen. There were no problems with it so far, until yesterday. I ran a software update and since then it's not able to boot anymore. First I got the Galaxy logo, but now just a white blank screen and the phone gets really warm. What I have done so far:
    - Battery in - out, try to switch on - just got the white screen
    - Recovery mode - no sign, white screen
    - Download mode - YES, finally I got it (a screen the text), but now I would really appreciate YOUR help
    I'm curious how to go on, since I'm not a phone geek at all.. So what do you do with the ' your model number/carrier/region/firmware version.'??
    PS: Could the thing with the stuck power button be an issue? After putting the battery back the white screen appears automatically without pressing any button
  23. #223
    Quote Originally Posted by Ansahor View Post
    That sounds like a typical symptom of a stuck Power button/switch. You should pursue that fix until the phone no longer turns itself on when you insert the battery; then come back and we'll look at any booting issue.
  1. Xoom will not turn on
    By FireGuy303 in forum Motorola Xoom
    Last Post: 10-31-2013, 08:17 AM
  2. Droid's Screen Will Not Turn On??
    By GAlex067 in forum Motorola Droid
    Last Post: 01-19-2011, 08:22 AM
  3. blackflip will not turn on!!!!!!1
    By bigheadtony6 in forum Motorola Backflip
    Last Post: 11-04-2010, 04:02 PM
  4. Inc will not turn on, no charge light
    By monkeymisfit in forum Verizon Droid Incredible
    Last Post: 09-23-2010, 10:29 PM
  5. Phone will not turn on
    By kvaughan#AC in forum Verizon Fascinate
    Last Post: 09-14-2010, 08:39 AM
B
