Re: LED light not working :(
Check to see if quiet hours are on in your settings
There is a jelly Bean feature that can turn off the notification light and other setting during certain hours ago to find it, I believe you have to go through sound settings first
Sent from my SPH - L710 running Pac Man Rom, like a #Bawse
My blocking mode is off so I dont think that is it
I'm assuming you got the replacement from a warranty claim right?
Chances are it's a refurbished device and this is a hardware issue. They should be able to over night you a device if you call right away.
Galaxy S3 - Thanks Appreciated!
My Podcast-[Only registered and activated users can see links. Click Here To Register...]
My Blog-[Only registered and activated users can see links. Click Here To Register...]
Yes, you are correct. I did do this through a warranty claim. Ohhhh what a bummer!!!! I finally got everything set up. I dont know if I really want to do that again :( I guess now I know I will check that setting before spending so much time getting it how I want it.
Do the led light up when charging? Might tell you if it don't work at all or maybe a setting issue.
Sent from my SCH-I535 using Android Central Forums
I know that feeling lol. Just do while your at work so you're getting paid and killing time ;)
I like the way you think, lol!!! It doesnt turn red when charging either. I was going to try and see if I really need it and live without it to avoid setting it up, but its not worth it. I think I will have to go ahead and bite the bullet and set up a 6th phone in 4 months! Hopefully this will be the end of it. Thanks guys!
My Podcast-
My Blog-
