1. melissamk1979's Avatar
    I just got my new Galaxy 3 today, insurance had to send me a new one because I shattered the screen on my one week old one. I finally got all my settings the way I want them and realized that the LED light is not working. I have notificiations LED lights set to on so I have no clue what is going on. I did some google help and tried the testing of the LED lights in the phone keyboard screen when you type *#0*# the led lights do not come on. Does anyone have any clue what could be wrong? I really want my LED lights to come on, but I do not want to have to return the phone and set up another.
    Thank you for your help!
    12-15-2012 09:48 PM
  2. Soundtrack to Chaos's Avatar
    Check to see if quiet hours are on in your settings
    There is a jelly Bean feature that can turn off the notification light and other setting during certain hours ago to find it, I believe you have to go through sound settings first
    Sent from my SPH - L710 running Pac Man Rom, like a #Bawse
    12-15-2012 09:51 PM
  3. melissamk1979's Avatar
    My blocking mode is off so I dont think that is it
    12-15-2012 10:02 PM
  4. Srambo217's Avatar
    I'm assuming you got the replacement from a warranty claim right?
    Chances are it's a refurbished device and this is a hardware issue. They should be able to over night you a device if you call right away.
    Galaxy SIII - Thanks Appreciated!
    My Podcast-http://cyberears.com/index.php/Show/audio/6030
    My Blog-https://www.blogger.com/blogin.g?blo....blogspot.com/
    12-15-2012 11:32 PM
  5. melissamk1979's Avatar
    Yes, you are correct. I did do this through a warranty claim. Ohhhh what a bummer!!!! I finally got everything set up. I dont know if I really want to do that again I guess now I know I will check that setting before spending so much time getting it how I want it.
    12-16-2012 07:14 AM
  6. blade22222's Avatar
    Do the led light up when charging? Might tell you if it don't work at all or maybe a setting issue.
    Sent from my SCH-I535 using Android Central Forums
    12-16-2012 08:06 AM
  7. Srambo217's Avatar
    I know that feeling lol. Just do while your at work so you're getting paid and killing time
    12-16-2012 12:30 PM
  8. melissamk1979's Avatar
    I like the way you think, lol!!! It doesnt turn red when charging either. I was going to try and see if I really need it and live without it to avoid setting it up, but its not worth it. I think I will have to go ahead and bite the bullet and set up a 6th phone in 4 months! Hopefully this will be the end of it. Thanks guys!
    My Podcast-Podcast Hosting | People Friendly
    My Blog-Bear Pasta Rocket Pop
    12-16-2012 06:08 PM
  1. Notification LED light not working AT ALL, even while charging.
    By gixxerkid in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 12-16-2012, 07:46 PM
  2. Replies: 9
    Last Post: 02-11-2012, 02:28 PM
  3. Led Notifications not working.
    By Addie_Goodvibes in forum Sprint Epic 4G
    Last Post: 11-02-2010, 12:38 AM
  4. Notification flash (LED) off - not working
    By Peanutbutter_N_Jelly in forum Verizon Droid Incredible
    Last Post: 06-07-2010, 11:37 AM
  5. LED Notification not working
    By Goodness in forum Verizon Droid Incredible
    Last Post: 05-05-2010, 04:07 PM
