Results 1 to 3 of 3
    Default How to Remove Fonts on the S3
    Hey there, hope I can get some help on this. I found a zip file with over 280 Fonts and installed about 50 of them on to my phone. Chronologically, all the A's and B's. Just glad I didn't finish the C-Z's. The problem is, when I go into settings to change to a new Font, it takes forever to load up the Font list, asuming it has to read all of them first and takes forever to do it. I added them to my SD Card and just started unpacking like a wild fool. HUGE mistake. I cant seem to find on the File Explorer where they loaded to internally. Would much appreciate if someone can guide me through to find them, so I can remove them....
  2. #2
    Default Re: How to Remove Fonts on the S3
    Quote Originally Posted by paparock6969 View Post
    Go to Play Store and download Astro File Manager (there's a free version). Then open Astro and go to Searches>My Files>Folders>Download>then scroll to the font you want to delete and long press on it> then hit the garbage can icon and you will delete it. After deleting all of the fonts that you want, you'll need to re-boot your phone and the fonts should all be gone from your font list.
    Thank you for the info. I thought for sure I already had Astro installed, but didn't. While searching for it, I saw TaskMngr and had remembered I unistalled a few apps from there, checked and was able to uninstall Fonts using that. Just go to Task Mngr..open downloads from top menu..scroll list and uninstall whatever need be with no need to reboot..(Default Fonts were not there, maybe Astro would be better for that). All apps are there as well.
    Sidenote for all...don't fill up Font list..!! Choose wisely.
  1. How to remove and insert the microSD card
    By Phil Nickinson in forum AT&T Samsung Infuse
    Last Post: 06-20-2012, 02:15 PM
  2. [Guide] How to remove Bloatware from the Thunderbolt
    By Cory Streater in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 04-30-2012, 02:14 PM
  3. How to delete bookmarks on the HTC EVO 4G?
    By Carol00Clark in forum HTC EVO 4G
    Last Post: 02-18-2012, 11:24 AM
  4. How to clear everything on the captivate
    By Visual360 in forum AT&T Captivate
    Last Post: 01-22-2011, 04:05 PM
  5. Replies: 6
    Last Post: 07-23-2010, 07:52 AM
