i NEED help about "Motion" submenu
i just bought a samsung galaxy s3 GT I9300 and i just found out that there's no "Motion" submenu in settings.What seems to be the problem?
here's a pic:
[Only registered and activated users can see links. Click Here To Register...]
-Android Version ( 4.1.1 )
-Baseband Version ( MAUI.11AMD.W11.50.SP.V12, 2012/09/20 18:56 )
-Kernel version (3.0.13 / root@liyunpen-desktop #1 / Tue Nov 27 16:14:20 CST 2012 )
-Build Number ( ALPS.ICS.MP.V2.6 )
-custom build version ( 002121127 )
Re: i NEED help about "Motion" submenu
If you are rooted and running a custom rom, it removes the Samsung features including the motion features
Not all roms just aosp ones. (the ones that basically turn your phone into a Nexus device).
i'm sorry but i don't understand what that means.. im not kinda techy, this is the first time i bought a smart phone. what can i do to make the motion features available for my unit?
Where did you buy it from?
According to your stats, your phone seems to be rooted (hacked to break carrier limitations), and you might be running a custom rom (another version of the android software custom made by someone else other than Samsung).
If you wanted to return to stock android (how it would be if you bought it brand new from Samsung, Best Buy, or another official wireless provider), you would have to flash (re-install) it with the stock software, which can be found on the internet
Hope that was understandable enough for you lol
haha i think i already understand it.. somehow..
i googled some site, do you think this will help? should i follow the steps?
here's the link: [Only registered and activated users can see links. Click Here To Register...]
here's the link:
Yup! That should be it lol follow those instructions and you should be good with ur motion features
