If I program an NFC tag to say, turn on Wifi or open up an app, and my friend places his phone on the same tag, will it do the same for his phone? Or are NFC tags matched up with a specific phone?
Printable View
I think they are specific to the phone. At least for the Samsung NFC tags because I remember reading that one disadvantage to locking the tag from re-writes is that it will not allow any modifications including adding an additional device to the NFC list.
It depends on what you mean by 'a specific phone' - NFC tags that you've programmed on your SGSIII should work on anyone else's SGSIII, but I don't know if they will work on a different model phone that also has NFC capabilities (I haven't tried that). Several of us at the office, on different carriers, were able to use the same NFC tags. I'd recommend [Only registered and activated users can see links. Click Here To Register...] - it's much better than the stock app.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
Samsung nfc tags work with any phone.. I tried a tag at my local Costco cell phone kiosk and it worked fine for my GS3 :D
Sent from my SCH-I535 using Android Central Forums
What happens if you program it to do something that someone else's phone doesn't have? For example, if I program it to open Angry Birds and my friend doesn't have Angry Birds, does his phone just say "App cannot be found"?
Does this also mean that you can do malicious things with the tags? Can you program a tag to erase all data for example?
I think if your friend doenst have Angry Birds, the Play Store will probably open up and have them download the app.Quote:
Originally Posted by jamesino [Only registered and activated users can see links. Click Here To Register...]
Yeah this is exactly what will happen...if ur program it for an app and another phone doesnt have the app, it will open the play store and direct the phone to the appQuote:
Originally Posted by alicechong7789 [Only registered and activated users can see links. Click Here To Register...]
NFC Tags are not paired with phones the way Bluetooth is, but whether it will do the same thing on your phone as someone else's is entirely dependent on what that specific thing is. Most phones have default behaviors when reading an NFC tag and encountering common NFC data, for example if it reads a web site, it will launch the browser and nav to the site. However for scripts, such as TecTiles or NFC Task Launcher, you will need to have the scripting app installed in order to even run the script and then yes, you will need the same apps the script calls on your phone or it will not work.
