Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Almeuit
    Default No Audio Through Headphone Jack Once Locked
    I noticed since I updated to 4.1.1. that audio doesn't work through headset jack once I lock my homescreen. It works fine while the screen is unlocked but as soon as i lock it or autolock the audio stops coming through headphones but continues playing on external speaker at a low volume. Help please!!!!
  2. #2
    Default Re: No Audio Through Headphone Jack Once Locked
    Quote Originally Posted by chaselawson2007 View Post
    What application are you using? Are you playing music from your phone using one of the various music players? Or is this streamed music from Pandora, slacker radio, etc.
    Or is this cached music on your phone from a streaming place such as slacker radio, spotify, etc?
    Sent from my Sprint S3 using AC forums
    funkylogik likes this.
    Default
    Quote Originally Posted by Almeuit View Post
    From the phones default music player
    Bump
  5. #5
    rcook55's Avatar
    Posts
    ROM
    Back to Stock TW
    I noticed this as well. Using Samsung's music player or Pocket Casts if I start audio with the screen on, then turn off the screen, the audio is switched to the speaker. I found what works to fix the problem is to queue up what you want to listen to, kill the screen, then use the inline remote on the earbuds to start up the music/podcast and it will play though the earbuds/headphones. I don't know of a solution that doesn't require the inline remote.
    Oddly however, Pandora does not display this issue. You can start Pandora with headphones and kill the screen and it will continue to play as you would expect. Not a programmer so I can't speculate what is going on but there is an issue here.
    Is there somewhere to submit bugs to Samsung?
  6. #6
    They have a support section on their web site.
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
  7. #7
    rcook55's Avatar
    Posts
    ROM
    Back to Stock TW
    Quote Originally Posted by meyerweb View Post
    Don't bother, they make the model number a required field but then forgot to populate the drop down menu with SGH-I747 as a choice, you literally can't email them using the support sites method.
  8. #8
    rcook55's Avatar
    Posts
    ROM
    Back to Stock TW
    Are you running widget locker by chance? Once I disable widget locker this isn't a problem any longer.
  1. Can I get video through HDMI and audio through headphone jack?
    By urban ali in forum General Help and How To
    Last Post: 11-01-2012, 02:49 PM
  2. Playing audio through headphone jack; using bluetooth
    By jhimebau in forum Verizon HTC Thunderbolt
    Last Post: 04-26-2012, 03:46 PM
  3. Netflix no audio thru headphone jack . . .
    By expidia in forum Verizon Droid Charge
    Last Post: 07-23-2011, 07:41 AM
  4. Audio skipping through headphone jack
    By dcross9818 in forum HTC EVO 4G
    Last Post: 10-19-2010, 11:01 PM
  5. sound quality and loudness through headphone jack
    By jasonb in forum Verizon Droid Incredible
    Last Post: 04-22-2010, 08:43 PM
