Possible to invert home button function ala WebOS?
Hi there, I'm a former Palm Pre user and PreCentral member. I loved WebOS but the Pre's hardware and app development left a lot to be desired. However until Android 4 I had no interest in switching as the interface was previously clunky and ugly to me. I recently upgraded to a Sprint Galaxy S3 running Jelly Bean, and the hardware thus far is excellent.
What I've realized though that bothers me about Android vs. WebOS isn't the lack of "cards" although those would be nice. Given the app switcher function of the home button, this accomplishes much of what cards does. However, the home button works in what is a counterintuitive way to me. When you press it once, it takes you to the home screen, whereas you have to hold it down to get to the app switcher and even worse, you can't swipe the app you're in away without first going to the home screen or another app. I don't need to go home nearly as often as to another running app. Is there a way to invert this; i.e. pressing the home button once brings you to the app switcher whereas holding it down brings you home? And how about the ability to swipe away the currently active app from that screen? Those simple changes, which seem obvious, would save a lot of time and button pressing. Thanks in advance for any guidance!
Re: Possible to invert home button function ala WebOS?
Had my palm pre 3 years. I miss it but the Galaxy s3 is much better but to answer your question. Long story short. Nope
Check out wave launcher in the play store though it brings the good memories of the Web os days back.
Actually there are a few options.
If you don't mind using a different launcher, both Apex and Nova let you switch what the home button does (and one of the options is to open recent apps).
You could also use an app called Home2 Shortcut, which will let you set a double tap of the home button (or several other combinations) to pull up the recent apps. Unfortunately it won't let you set a single tap to an action, so if you want that, use one of the launchers mentioned previously.
Hope that helps.
Button Savior: [Only registered and activated users can see links. Click Here To Register...]
This is my solution - one of the buttons that it provides is the recent task list, so I pretty much never use the actual Home button.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
