Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By meyerweb
  • 2 Post By sledge007
  • 1 Post By makaroni
  • 1 Post By sledge007
  • 1 Post By monkeydog
    meyerweb's Avatar
    Posts
    Global Posts
    10,320 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Work around for my biggest S3 gripe
    As a number of people have noted in this thread:
    http://forums.androidcentral.com/sam...galaxy-s3.html
    It's way too easy to accidentally change the volume when hitting the power button. The application RingGuard will prevent inadvertent volume changes by requiring you to confirm any change, and reverting to the previously set volume if you choose "No" or don't confirm at all. You can set the wait time between 5 seconds and 60 seconds. (I have it set to 5.) Having to confirm a desired volume change is, for me at least, much less of a pain than constantly having to reset the volume because I hit the volume keys while intending to hit only the power button.
    https://play.google.com/store/apps/d...roid.ringguard
    Bsheedy likes this.
  2. #2
    sledge007's Avatar
    Posts
    Global Posts
    6,917 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Wicked Sensations
    Default Re: Work around for my biggest S3 gripe
    Way too easy? Can't say I've had this problem now or ever.
    crester and 20blks like this.
  3. #3
    makaroni's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I posted in the other thread and this was probably my only gripe but having to confirm a volume change seems a bit much. Just in my opinion though. I'd rather just try and work around it
    My GS3 sleeps in the bed and I make my girlfriend sleep on the couch
    ansextra likes this.
    meyerweb's Avatar
    Posts
    Global Posts
    10,320 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sledge007 View Post
    Then you won't be interested in the app. But because the volume and power buttons are directly opposite each other, I tend to have my fingers and thumb opposite each other when operating the power button. And I'm not alone.
  5. #5
    crester's Avatar
    Posts
    Global Posts
    648 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by meyerweb View Post
    It's just something you will get used to...
  6. #6
    sledge007's Avatar
    Posts
    Global Posts
    6,917 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Wicked Sensations
    Guess I just learned how to not push them together.
    My biggest gripe with the SGS3 is the BT Headset/Jellybean debacle.. Please fix that and I'll pay for that fix!
    crester likes this.
  7. #7
    lbkiml's Avatar
    Posts
    Global Posts
    289 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So i guess i can assume you're not using a case
    even with my thin case, its harder to press the volume and power buttons...
  8. #8
    Suntan's Avatar
    Posts
    Global Posts
    2,110 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'd have to say that after the first weekend of using the phone, I may accidentally press the volume button once a month at most when turning the phone off (I almost never use the power button to turn it on.)
    Even when it does get pressed, it only bumps it up or down one notch. I know it can be annoying from an anal-retentive point of view, but I don't find it too problematic. I certainly wouldn't consider it the biggest issue the phone has, but YMMV.
    I would suggest practicing turning it on/off while holding it in a manor that doesn't actuate the vol buttons. Repetition builds muscle memory and soon you won't be pressing the vol buttons much at all.
    -Suntan
  9. #9
    monkeydog's Avatar
    Posts
    Global Posts
    348 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Some of you people, I swear. He's talking about a phone, he's not insulting your children.
    Here's a guy who has a gripe, confirms that it's shared by multiple people, finds a solution and shares it freely. This is the behavior we want on a forum. If you don't have this problem, move along.
    I can imagine someone publishing a cure for lung cancer and some of you saying "You knew smoking was bad for you, so just deal with it."
    meyerweb likes this.
  10. #10
    Tkbredx's Avatar
    Posts
    Global Posts
    2,123 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    TeamSonicFreeGS3 v9.1
    Never had this problem either but glad you got it worked out
  11. #11
    makaroni's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by monkeydog View Post
    Yep. I'd be the first to say it too. It's a forum for us to speak freely. We're happy for his solution and I'm sure it may help a few people if this problem is really a big one for them. Just some of us have a different view on it. And to the OP, if my post was said in a way that might make you think twice about posting again... I apologize. That wasn't my intention. Peace to all and nothing but the best for the New Year
  12. #12
    Shanicenicolle's Avatar
    Posts
    Global Posts
    1,921 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I agree 100%
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
  13. #13
    kevinocarro's Avatar
    Posts
    Global Posts
    21 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  1. Work around for Google Voice voicemail with the S3?
    By qdtphotog in forum Verizon Galaxy S3
    Last Post: 07-11-2012, 06:38 PM
  2. (EVO3D) Work Around For Using WiiMotes On Video Game Emulators?
    By the2ndflood in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 12-21-2011, 08:15 PM
  3. [HOW-TO] Work-arounds for issues with stock Nook Color ROM
    By hitman-_-45-_- in forum Barnes & Noble Nook Color
    Last Post: 03-25-2011, 06:36 AM
  4. AT&T approved work around for OTA update problems
    By Redneckbutlerboy in forum AT&T Captivate
    Last Post: 10-13-2010, 11:20 PM
  5. Work around for Voice Dial
    By ramireh3 in forum Verizon Droid Incredible
    Last Post: 09-04-2010, 02:40 PM
