Results 1 to 22 of 22
Like Tree3Likes
  • 1 Post By Incitatus
  • 1 Post By MaranaxSG3
  • 2 Post By meyerweb
    not2gutta's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Why is gmaps consuming my battery?
    I took my phone off the charger at 100% before going to bed last night. I turned off data to keep it fully charged. This morning it was down to 70% and when I looked at the battery stats, it shows gmaps was running..though it wasn't present in my recent run apps nor was my gps on. Any idears?
    Sent from my SCH-I535 using Tapatalk 2
    Attached Thumbnails Attached Thumbnails Why is gmaps consuming my battery?-uploadfromtaptalk1357235841209.jpg
  2. #2
    gwappa's Avatar
    Posts
    Global Posts
    191 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Why is gmaps consuming my battery?
    If you're on Jellybean then it's more than likely Google Now's hammering the location services - turn off Wifi in location services, however you will lose some functionality in Google Now.
  3. #3
    crester's Avatar
    Posts
    Global Posts
    648 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That looks weird... 50% of your battery is being consumed by Google Maps?!?!?! Does this happen on a regular basis?
  4. #4
    MaranaxSG3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lightbulb Re: Why is gmaps consuming my battery?
    I had the same problem. After charging the battery up to 100% and placed it during the night. So, basically in sleep mode, my battery was drained to 20%. Just for 6 hours! So, what I would recommend you to do: open Google Maps, click on Options (left button), Settings, Location Settings and uncheck "Report from this device". Google location reports your location every 2 minutes. So, it drains your battery.
    I also recommend you to install JuiceDefender. It's free and it helps to extend the battery life.
    Hope it helps.
  5. #5
    ansextra's Avatar
    Posts
    Global Posts
    1,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MaranaxSG3 View Post
    Hope it helps.
    Other than Juice Defender I agree with the above post completely. I had already done the settings changes and battery life increased tremendously.
  6. #6
    Incitatus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was having the same issues, deleted Savvy Shopper app and GMaps battery usage went from 30%, down to 3%.
    Think of other apps using your location, not just gmaps.
    Good luck.
    crester likes this.
    not2gutta's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the information, good to know! I disabled Google now as soon as I received jelly bean so not sure if that's it. Though I didn't know Google maps reported my location so often like that, so I made sure to unchecked that! I may try juice defender, use to have that on my nexus. I'm also going to go through my apps, deff could be a factor in this issue. Appreciate the feedback! B)
  8. #8
    AxlMyk's Avatar
    Posts
    Global Posts
    1,247 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Don't use Google Now.
    --Tapatalk on Samsung GS3.
    not2gutta's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well it occurred again last night. I have Google now disabled I believe, though when I use the Google search bar it goes through Google now. How can I find out if an app is causing gmaps to run?
    Attached Thumbnails Attached Thumbnails Why is gmaps consuming my battery?-uploadfromtaptalk1357317785485.jpg
  10. #10
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    I use google now and keep wifi on and maps enabled
    On ICS, maps used to eat my batt so i kept it disabled
    Unbranded international rooted s3 with Official 4.1.2 JB. Paisley, Scotland, Western Europe :beer:
  11. #11
    youngzayiles's Avatar
    Posts
    Global Posts
    931 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Its a bad app thats using your location through google. Any location using apps??
    ONE BAD *** NOTE 2 ON A BAD *** JELLY ☆BEANS☆ ROM
  12. #12
    goin_nil's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by not2gutta View Post
    You could try Watchdog app to see if something is consuming a lot of CPU.
    Use GSam Battery Monitor too to find more detail about the top battery consuming apps.
  13. #13
    MaranaxSG3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Interesting... My guess - it could be running GPS...
    funkylogik likes this.
  14. #14
    Incitatus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have Google Now on, using about 75% of the functions, wifi on and gps on 24/7. My battery drain was from a 3rd party app, I'd bet the culprit is a 3rd party app in most situations.
    Just checked again, in 5 hours since being unplugged gmaps has used 1.5% of battery. Prior to removing the 3rd party app it was typically 30%, sometimes 38% usage.
    GroupOn, Savvy Shopper, etc. The apps that push local content to you. Delete them one or two at a time until you find which one it is.
  15. #15
    MaranaxSG3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you have Jelly Bean or ICS?
  16. #16
    Incitatus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    SGS3 Tmo JB for me.
  17. #17
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Dont use gps for Now. Wifi+data works fine at lettin the phone know where it is n uses like 1% (wifi)
  18. #18
    meyerweb's Avatar
    Posts
    Global Posts
    10,320 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    With JB, the phone will control GPS. Even if you have it turned on, it only draws power if an app is using it. When it's being used, you'll see the GPS icon in the notification bar. When it's on, but not being used, the notification icon goes away.
    Check to see if you have Latitude set up to do location reporting. That will keep the maps app active, and suck battery. Go to settings / Google / Maps & Latitude and make sure "Report from this device," "Enable location sharing," and "Automatic check-ins" are shut off.
    funkylogik and kfrodgers like this.
  19. #19
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Quote Originally Posted by meyerweb View Post
    Ive heard what youre sayin bro n i believe it but GPS murders my battery.
    Probably just my phone
    P.s i did read your whole post mate lol
  20. #20
    meyerweb's Avatar
    Posts
    Global Posts
    10,320 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I leave GPS turned on all the time. Maps has used only 7% of my battery in the last 9 days, and I've used the phone to navigate a few times. If the GPS is using a lot of battery, I think it's because some app is actually requesting location services.
  21. #21
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    7% is 7% no matter how many days bro. think of how percentages work, its a ratio, not an amount. 10% would mean a tenth of your battery had been wasted/used by something
    having said that, if youve used maps a lot but after 9days its still at 7%... thats a lot of battery use
  22. #22
    meyerweb's Avatar
    Posts
    Global Posts
    10,320 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No duh. But like I said, I've USED the maps app to do navigation, so some usage is expected. The point is it's NOT killing my battery. I easily get 12-15 hours out of a full charge. The usage the OP is showing is not normal for maps. SOMETHING is actively using the GPS, and he needs to figure out what.
  1. What is 'Mediaserver' and why is it draining my battery so much?
    By Chocoburger in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-05-2016, 07:48 PM
  2. What is MediaServer and why is it killing my battery?
    By winste in forum Verizon Galaxy Nexus
    Last Post: 03-14-2014, 05:06 AM
  3. Why is Gallery sucking my battery dry?
    By boristhebad in forum Samsung Galaxy S3
    Last Post: 01-21-2013, 05:29 PM
  4. What is this and why is it murdering my battery?
    By Happenstance in forum General Help and How To
    Last Post: 04-28-2011, 11:19 PM
  5. What is this Notification Icon? and is it killing my battery ?
    By James_Irwin in forum Verizon Droid Incredible
    Last Post: 08-02-2010, 06:25 PM
