Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By KreepyKen
    Liane63's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Galaxy S3 problems
    Hi
    I have had my phone for a while and had it just the way I like it. Late Dec, an upgrade came through and upgraded my phone to 4.1.1 baseband I9300XXDLID. Since then, the battery life sux. I have looked to see what is sucking it up but cant work it out. Also, how the heck do I turn of notifications? The widget thingy has disappeared from the notifications bar and also in settings.
    Help...please!!!!
    Thanks
    Liane
  2. #2
    robersk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy S3 problems
    My battery life has been horrible as well, I only got my handset a few months ago but have found the battery life to be really bad as well. I find turning off WiFi and GPS when not using them as well as turning off mobile data when I'm not using the device helps a lot. Not sure about the notifications.
    Liane63's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Before the upgrade if was fantastic but now...its not. Is anyone else having trouble after the latest upgrade?
  4. #4
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    So annoying they took notification toggle away! .......like WHY?
    If the battery life is SERIOUSLY worse since JB then factory reset
    Unbranded international rooted s3 with Official 4.1.2 JB. Paisley, Scotland, Western Europe :beer:
  5. #5
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    touchejiz
    Wow how DO u turn of not's now?
    Just had quick scan through settings and ?
  6. #6
    meyerweb's Avatar
    Posts
    Global Posts
    10,320 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by funkylogik View Post
    A couple of ways. In Settings / Application Manager, in each app page there's a checkbox for notifications. (at least in 4.1.1).
    Or, when you have a notification in the pulldown, long tap. That'll display an "App info" button. Tapping that button will take you to the same screen as above.
  7. #7
    meyerweb's Avatar
    Posts
    Global Posts
    10,320 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Liane63 View Post
    Hi
    Liane
    Many who had battery issues after the update have found a hard reset solve the problem. Yeah, that sucks.
    If that doesn't do it, try the app System Panel. It has a monitoring mode that will log what applications are doing in the background, which may help you discover what's eating your battery.
    What carrier are you on, and do you have where you are? There have been reports of phones killing batteries while searching for LTE in areas where it doesn't exist. Look here:
    http://forums.androidcentral.com/sam...-per-hour.html
    and here:
    http://forums.androidcentral.com/sam...a-plummet.html
  8. #8
    makaroni's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    "media" was sucking up all my battery life so i did a factory reset like everyone said I should do and disabled all antivirus apps and keyboards so I did. After restoring all my data and my apps my battery life went back to normal with my normal usage. However some of my music files were no longer working through my "player pro" app so maybe the update caused that but I'm not sure. I deleted all my music files and reloaded them and now they seem to be working fine. someone also mentioned that there may be corrupted files on your phone or SD card and can cause "media" to eat up your battery juice. So if "media" is draining all of your battery life, try removing your media files and putting them back on the SD card or internal storage and see what happens. "Android system" seems to be the only thing using a decent amount of battery life on my phone now but it's normal and my phone is running fine. Good Luck and long press the power button and there is an option to turn off notifications or put the phone on vibrate since there's no toggle in the pull down
  9. #9
    ShaggyKids's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I haven't noticed any battery life differences since my upgrade several weeks ago. I'm on VZW if that matters.
  10. #10
    crester's Avatar
    Posts
    Global Posts
    648 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For those wondering about the Notifications toggle... Blocking Mode does the same thing and more.
  11. #11
    KreepyKen's Avatar
    Just a cool guy
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Unrooted with Nova Prime
    Quote Originally Posted by crester View Post
    Yes. Open the Blocking Mode settings and check "Disable Notifications" and then check "Always."
    crester likes this.
  12. #12
    KreepyKen's Avatar
    Just a cool guy
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by meyerweb View Post
    and here:
    The problem is not that it is looking for LTE where there is none. It's a problem with LTE being present and the phone can't resolve which network to use. For me, it happens periodically when I'm in an LTE area but have wifi turned on & connected. The phone should disable mobile data at that point, but it looks like it tries to use it anyway and freaks out, causing the battery to spin out of control. It has never once happened to me when outside of an LTE area. It's very irritating.
  1. Galaxy S3 problems using Ibolt car dock with Car Home Untra
    By Neal Edwards in forum General Help and How To
    Last Post: 11-09-2012, 10:23 AM
  2. Samsung Galaxy S3 4G problems
    By DEMF_crazy in forum Samsung Galaxy S3
    Last Post: 08-22-2012, 11:15 PM
  3. Galaxy S3 Unlocked Network Problem
    By brersam in forum Samsung Galaxy S3
    Last Post: 07-02-2012, 06:14 PM
  4. does galaxy s3 have same problems as the nexus on verizon?
    By droid747 in forum Verizon Galaxy S3
    Last Post: 06-05-2012, 09:21 AM
  5. does galaxy s3 have same problems as the nexus on verizon?
    By droid747 in forum Samsung Galaxy S3
