Say goodbye to lag (rooted users)
[Only registered and activated users can see links. Click Here To Register...]
Check out this all called seeder guys, I didn't believe it would actually work, but it does, im not even sure how, but everything runs smoother, images from apps like instaagram load quickly, no lag when going back to your launcher after exiting an app, even removing apps from your task manager feels smoother
Even the slowest thing on my phone, the go launcher app drawer, is much smoother
All for 1.40$
Check it out, it's well worth it
Sent from my SPH - L710 running Pac Man Rom 4.1.2
My notification bar >>>>>> yours
Re: Say goodbye to lag (rooted users)
I got it. Never really had lag in the first place. Idk though. I'll keep it but i think it's just the placebo affect
In fact i ran a quadrant and went under 400 points after i got this app
Really? I'll run one myself later
I don't think it's meant to boost ur score but overall performance wise, I feel most things on my phone are much much much smoother and a lot less lag especially with go launcher, which is usually slow as crap, especially they're app drawer which might as well have been a slide show prior to getting this app
Sent from my SPH - L710 running Pac Man Rom 4.1.2, seeder and ktweaker kernel underclocked to 1242 ghz, and my phone still runs laps around the competition
This app causes a placebo effect and in most cases could cause more problems then it does good. There was an article about it recently let me see if i can find it.
Its because it keeps your CPU awake and running at higher clock rates. If you have something to log CPU speeds and times you could test an average day with and without it.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Basically enjoy your sugar pill and probably diminished battery life.
A few days back I read 40+ pages on XDA on this. While I was excited at first I came away concluding that this probably will help older phones, but not your S3. If you read the whole thread you will understand why.
It won't "help" any phone. All it does is effectively disable CPU throttling causing the CPU to run at full rated speed all the time giving the illusion of a faster phone. The only other outcome that will come from this is lowered battery life. This is nothing more than a 'registry tweak' from Win95 days.
1 Attachment(s)
This is from the past few hours
I'm using the Ktoonservative governor so I shld be fine
But I do notice one thing, I believe seeder is preventing ktweaker from locking the clock speed, but is using the gouvenour still
Edit: Nvm, i fixed the issue, stupid ktweaker wasn't saving applying my settings correctly, lol
Now I'm back to 1242
Can someone explain the placebo effect to me please? Sorry
Oh I get it now, thanks
I Googled placebo effect android prior to asking and found nothing that would help , but now I see what you are saying, it's not related to android, but like in general
But this is no placebo effect, it clearly does something because prior to it, my go launcher app drawer would be soo slow and laggy, and now it's not
I have an app that makes my screen turn off once I put my device face down, and now it works faster
Loading people's instagram pictures pages now loads the images faster
These things are legit. I don't feel it affects every app but it does indeed work
Sent from my Google Nexus 7 running aokp 4.1.2, because there is no PacMan rom for the nexus :(
Meh, got an extended battery, so it doesn't bother me much, get about 2days and a half with light usage
Still not sure. I have felt like a couple apps were opening faster but i still don't know. I asked for a refund. If he gives the refund to me then I'll take it. If he doesn't then oh well
I wouldn't say you open apps faster, i haven't particularly seen that, I've just seen situations that previously had lag or little hitches, no longer having it and images rendering faster in certain apps
It's well worth the 1$
What lag are people talking about? My phone runs great from what I can tell... Or does it run even better after this tweak/fix?
:confused:
Sent from my Sprint S3 using AC forums
:confused:
Don't know how to describe it, but in most situations, it just makes things smoother
Only certain things lagged for me in the past, specifically the go launcher app drawer, now it's fixed.
Let's just say this makes ur phone smoother
I've been running Seeder V6 since last week. I've noticed some things may seem a bit faster but I also feel I'm using battery faster. No two days are exactly the same for me usage wise so I don't have empirical evidence to back up my feelings. There's always a cost.
I plan on running my own testing I have some tools to measure CPU usage and loads as well as monitoring the app itself to see how it affects my system overall. I'm not expecting much usable data but I can hope.
There are literally thousands of posts talking about this on XDA. The consensus seems to be equally divided on good/bad. Some claim enormous gains (no pills involved), and others say it ruined their lives. Most seem somewhere near the middle, like me, and can't see much in either direction.
I got my refund. Was the app supposed to disappear? I still have it. Guess I'll keep it lol
