Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By funkylogik
    Joe113's Avatar
    Banned
    Posts
    Global Posts
    833 Global Posts
    ROM
    Liquid Smooth [4.2.2]
    Default Best Battery Monitoring App is....?
    Right now I have GSam Battery Monitor, but I was wondering if there are any "better" apps to monitor my battery and see how it's being used? Thanks in advance.
  2. #2
    worwig's Avatar
    Posts
    Global Posts
    757 Global Posts
    Default Re: Best Battery Monitoring App is....?
    Battery Monitor Widget
  3. #3
    Battery stats plus
    Sent from my SPH - L710 running Pac Man Rom 4.1.2, seeder and ktweaker kernel
    Android is a tune up sports car with custom interior, sound system, and IOS is a stock model benz
    I use Android, because unlike IOS, i keep my apps in app drawers, and not infinitely cluttered homescreens
  4. #4
    gwappa's Avatar
    Posts
    Global Posts
    184 Global Posts
    Or Better Battery Stats, very good at wakelocks.
  5. #5
    funkylogik's Avatar
    Posts
    Global Posts
    9,696 Global Posts
    ROM
    touchejiz
    Stick with Gsam and Cpu Spy bro
    Unbranded international rooted s3 with Official 4.1.2 JB. Paisley, Scotland, Western Europe :beer:
    GT-I9300, UK
    Haalcyon likes this.
  6. #6
    Battery Drain Analyzer is also another good app. It tracks your battery and power usage behind-the-scenes to give you an idea of what’s using the most juice. The app will analyze app and power usage and let you know which apps are draining the most power, or if it’s even an app that’s causing battery drain. Been using it for a while now and I really like its usefulness. Check it out!
    HTC Sensation: Rooted, S-Off, SuperCID
    [BOOTLOADER] ENG S-OFF 1.17
    [RECOVERY] 4ext Touch Recovery v.1.0.0.5 RC9
    [RADIO] 11.76A.3504.00U_11.24A.3504.31_M
    [ROM] ViperS 5.0.0 JB Sense 5
    [BUILD] Based HTC 3.19.401.101 RUU Ville C2
    [RIL] HTC-RIL 4.0.0037HMQ
    [Kernel] 1.0.3 by SebastianFM
    [SD] 64GB Class10
    Asus Eee Pad Transformer
    Asus Eee Pad Transformer Prime (Rooted/Stock with JB)
  1. is there a battery monitor app that allows me to reset the
    By adaorange in forum Verizon HTC Thunderbolt
    Last Post: 07-10-2011, 03:52 PM
  2. Battery monitoring app
    By Comineeyeaha in forum Android Applications
    Last Post: 05-09-2011, 08:54 AM
  3. the best battery saver app
    By drummerman2008 in forum Verizon HTC Thunderbolt
    Last Post: 03-28-2011, 11:20 PM
  4. Best battery status app/widget?
    By JRodHimself in forum Android Applications
    Last Post: 08-22-2010, 10:10 AM
  5. Best Battery Assessment App
    By akarol in forum HTC EVO 4G
    Last Post: 06-10-2010, 01:29 PM
B
